Thread: Which roller rockers?
Results 1 to 15 of 15
spina74 Which roller rockers? 12-04-2009, 12:12 AM
OH4CompG Re: Which roller rockers? 12-04-2009, 12:59 AM
99prixgt Re: Which roller rockers? 12-04-2009, 02:13 AM
OH4CompG Re: Which roller rockers? 12-04-2009, 02:21 AM
99prixgt Re: Which roller rockers? 12-04-2009, 02:26 AM
OH4CompG Re: Which roller rockers? 12-06-2009, 08:11 PM
matt5112 Re: Which roller rockers? 12-04-2009, 07:49 AM
Bio248 Re: Which roller rockers? 12-04-2009, 09:15 AM
blowfishRus6 Re: Which roller rockers? 12-04-2009, 11:35 AM
spina74 Re: Which roller rockers? 12-04-2009, 05:11 PM
01gtspecial Re: Which roller rockers? 12-04-2009, 11:24 AM
blowfishRus6 Re: Which roller rockers? 12-04-2009, 06:24 PM
Bio248 Re: Which roller rockers? 12-04-2009, 06:27 PM
pontiackid Re: Which roller rockers? 12-06-2009, 06:28 PM
blueguy Re: Which roller rockers? 12-06-2009, 06:58 PM
  1. #1 Which roller rockers?
    SE Level Member spina74's Avatar
    blackwood
    Which roller rocker company should I get, I'm very familiar with Comp, but I'm not sure what is a common roller rocker that you guys run on the L67's. I'm either going with a 1.9 or a 1.8 and does anyone have the specs on the rockers for when I order them.
  2. #2 Re: Which roller rockers?
    Portland Oregon
    Get 1.8 if you want to keep stock valve springs. If you upgrade to 105's and want to shift higher than 6k then get 1.9's. I will be 1.9'd next year.
  3. #3 Re: Which roller rockers?
    Jersey
    i like my yella terras, they have a 1.95 option. aftermarket springs with the 1.9's are very debatable. I believe you need springs with 1.95's.
    16' wrx sti- stock
  4. #4 Re: Which roller rockers?
    Portland Oregon
    You need springs with 1.9's unless you want your stockers to bind and break on you. You wanna get technical, 1.84's are the highest ratio you can run on stock springs.
  5. #5 Re: Which roller rockers?
    Jersey
    Quote Originally Posted by OH4CompG View Post
    as i said, there is alot of debate, some guys use them with no problems, no float on stock springs, others upgrade the springs. I went with L76 springs on mine just to eliminate possible further problems.
    16' wrx sti- stock
  6. #6 Re: Which roller rockers?
    Portland Oregon
    Quote Originally Posted by 99prixgt View Post
    IIRC it's not about the float, it's about the amount of compression a stock valve spring can take before binding.
  7. #7 Re: Which roller rockers?
    Upgrade the springs anyways? If they're old you should change them anyways. If you want to rev higher, you might as well.
  8. #8 Re: Which roller rockers?
    with rollers you need to run bigger springs with anything over 1.8s. if youre going the roller rocker route and have committed to it then i would definitely go 1.95:1 ratio. otherwise just save yourself some money and get the modded 1.9s.
  9. #9 Re: Which roller rockers?
    Donating Users blowfishRus6's Avatar
    g.a.
    this. the modded 1.9s seem to be fine on the stock springs. but rollers is a diffrent story.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  10. #10 Re: Which roller rockers?
    blackwood
    How much of a pain is it getting to the back springs? I really don't want to tear the motor down to pull the heads off. I know I can just raise the piston to the very top and let the valve drop, but wouldn't it be a pain since the supercharger would be in the way? I apologize for the dumb questions, I usually only toy with RWD V8's and I know these motors can be a little bit touchy sometimes.
  11. #11 Re: Which roller rockers?
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    what about the zzp er rockers for the n/a set up. if i put those in and new springs...how much higher can i raise the rev lim?
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  12. #12 Re: Which roller rockers?
    g.a.
    its not all that difficult. just gotta reach. you probably will get cramps and anoyed from bending over and reaching for so long (damn that dident sound good) i had to take a break or two doing my rockers
    its slow.
  13. #13 Re: Which roller rockers?
    Quote Originally Posted by blowfishRus6 View Post
    true story.
  14. #14 Re: Which roller rockers?
    GT Level Member pontiackid's Avatar
    KCMO
    nonsense... hop up and sit on the motor, it'll be fine unlike your back after and hour.
  15. #15 Re: Which roller rockers?
    ^^Agreed. Spidermonkey that sh!t
  1. roller rockers.....help....plz
    By bigdawg15005 in forum General Tech Discussion
    Last Post: 09-13-2009, 03:22 PM
  2. roller rockers ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2008, 12:28 PM
  3. Roller Rockers
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 05:49 PM
