Thread: S/C wear pics
Results 1 to 20 of 21
  1. #1 S/C wear pics
    GT Level Member GOINDEF's Avatar
    Holly, MI
    I was wondering if anyone has pictures of their s/c blades or the inside of the housing. I noticed that the blades on my s/c are a little rough around the edges and looks like they might have ground the casing.
    So if anyone can show me some pics if they have them of how your casing and s/c blades looked before you cleaned them up or after, thatd be great.
    I'll try and get some pictures of them up tomorrow hopefully.
    Also how do i figure out if my s/c bearings for the blades are worn?
    Thanks for the help
  2. #2 Re: S/C wear pics
    Charles City, IA
    Do not take the black coating off the rotors or they are junk. Thats what makes them seal.
    SMGPFC Two Nipple General
  3. #3 Re: S/C wear pics
    Bastard Reptile's Avatar
    Kansas City, MO
    Minimal wear on the edge of the rotors where they contact the case is normal, but if it is deeply gouged, you have a problem.
  4. #4 Re: S/C wear pics
    Holly, MI
    the black coating around the edges of the rotors or on the actual blades, cause it looks like theres a bunch of carbon buildup or something all over the rotors and the inside of the housing
  5. #5 Re: S/C wear pics
    Charles City, IA
    The coating is all over the rotors. Just wipe them off with a rag if you want to clean them.
  6. #6 Re: S/C wear pics
    Holly, MI
    just wipe them off with a rag and brakleen or just a rag?
  7. #7 Re: S/C wear pics
    Charles City, IA
    I would just do a rag.
  8. #8 Re: S/C wear pics
    Holly, MI
    ok, so then I'll take that also that you dont want to put it in a wash bin either. is there anything to use for cleaning the rotors off, or should i just use soap and water to get it off
    also how do i take out the bearings that are in the housing, the housing is safe to put in the parts washer correct?
  9. #9 Re: S/C wear pics
    Banned - Busted For Scamming
    Feb 2009
    You can use brake cleaner or degreaser to clean off the carbon, wont hurt the rotor coating. If it comes off it was going to in your motor either way. Doesnt look bad ive seen worse and that will make boost.
  10. #10 Re: S/C wear pics
    Jersey
    I just used brake and t/b cleaner to clean mine. Worked well.
    16' wrx sti- stock
  11. #11 Re: S/C wear pics
    Holly, MI
    so the rotor doesnt look too bad then?, thats was my biggest concern. also how does the rotor bearings in the housing come out?
  12. #12 Re: S/C wear pics
    Feb 2009
    You have to press them out, with a grease gun
  13. #13 Re: S/C wear pics
    Holly, MI
    ?? how do i go about doin that?
  14. #14 Re: S/C wear pics
    Kansas City, MO
    Those look perfectly normal, even with some of the coating coming off.
    By pressing them out, he means that you have to drill, and then tap the two holes in the bottom of the case, then insert a grease zerk, then pump the chamber behind the bearings full of grease.
  15. #15 Re: S/C wear pics
    Holly, MI
    D*mn that sounds like a whore. so i looked at the case and there's 2 holes in the housing that are behind the bearings already ARE NOT tapped. is that where I put the grease fittings
  16. #16 Re: S/C wear pics
    Kansas City, MO
    Yep. I had a link saved at one time with all the things needed, but a virus took that away. Luckily for me I built a tool to do it, and it's kinda a pain because you have to use so much grease, and then it's a big damn mess...but apparently that's the only way to do it.
  17. #17 Re: S/C wear pics
    Feb 2009
  18. #18 Re: S/C wear pics
    DONT CLEAN THEM. LEAVE THE ROTORS ALONE!
    why do you people think cleaning them is a good idea? that "carbon buildup" is making you more boost. LEAVE IT THERE!
  19. #19 Re: S/C wear pics
    Holly, MI
    welp too late, cleaned them all and have the bearings out, I'll post pictures tomorrow, everyone at work keeps telling me that the case is shot cause it looks like there's grooves in it, but I think it might be ok?
    Like I said I'll take pictures tomorrow and post them so you guys can let me know.
  20. #20 Re: S/C wear pics
    Feb 2009
    doesnt matter its fine
  1. Tire wear on inside edges in back
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2014, 11:43 AM
  2. tire wear
    By izup69 in forum General Tech Discussion
    Last Post: 10-13-2009, 06:28 PM
  3. Dashboard Wear. Help.
    By Traeger2591 in forum Visual/Body Modifications
    Last Post: 07-24-2009, 12:58 PM
  4. Blower wear
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2009, 10:18 PM
  5. You asked for them... pics pics and more pics!
    By miller in forum Off Topic Discussion
    Last Post: 07-30-2008, 05:33 AM
