Thread: L67 cost
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: L67 cost
    Ohio
    Joe u spun a bearing. the crank is damaged due to the bearing failing the initial damage is not a result of the crank itself. the crank damage is a result of bearing. the bearing failed due to lack of oil pressure leaving the journals un lubricated causing the resulting damage u see on the bearing and crank.
    00 GTP demodded and forsale
  2. #22 Re: L67 cost
    GT Level Member silvermistchick's Avatar
    Jan 2009
    Atlanta, GA
    ^^ well how do you kep from doing that?? i dont want that happening to my baby
  3. #23 Re: L67 cost
    May 2008
    staten island,NY
    i have a low compression build and i have quite the fast M90 car
  4. #24 Re: L67 cost
    GT Level Member skidoojames151's Avatar
    seattle
    and it would be that much faster with higher compression...and you make more power out of boost as well
  5. #25 Re: L67 cost
    Quote Originally Posted by skidoojames151 View Post
    5% more power isn't THAT much.
  6. #26 Re: L67 cost
    Ohio
    Quote Originally Posted by silvermistchick View Post
    You take care of it and keep up on your oil changes. There are other things that can cause it as well though such as your oil pump failing. There is nothing i can tell u that can guarantee 100% that nothing will happen as long as u keep up on your maintenance it will help though. Around 100000 miles you should look at replacing important parts such as oil pump, water pump, timing set and things of that nature. that too will help to keep from anything drastic happening.
  7. #27 Re: L67 cost
    May 2008
    staten island,NY
    i run a 3.25pulley and make 255hp and 301tq to the tire with rockers. i make 30ftlbs more torque then when i was intercooled and L36 and only 10 less horsepower. i could care less about 5% when the 3.0 pulley will get me another 15hp and more torque
  1. cost of top swap
    By skidoojames151 in forum General Tech Discussion
    Last Post: 08-05-2009, 09:44 AM
  2. Building up a 3800... how much did it cost??
    By Iron Indian in forum General Tech Discussion
    Last Post: 07-20-2009, 10:09 PM
  3. Cost efficient mods
    By whitedudedown in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2008, 07:04 PM
