Thread: bad start
Results 1 to 7 of 7
  1. #1 bad start
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    ok just put on the ported supercharger it wouldn't start finally got it started and its leaking coolant and it runs really rough. any idea as in what would cause this?
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: bad start
    running rough woudl suggest vacuum leak. Coolant leak might mean something wasn't installed correctly. Take the super back off and make sure everything is sealed properly.
  3. #3 Re: bad start
    Grayslake
    Alright ill have to look at that again then. Thanks.
  4. #4 Re: bad start
    I know the throttle body is supposed to have a GM sealant on it. LIM gasket the aluminum one?
  5. #5 Re: bad start
    Donating Users kfish's Avatar
    Ohio
    where is it leaking coolant? did you put the o rings in the lim? you got got all the plugs right on the tb? i know 2 can be switched around.
  6. #6 Re: bad start
    Grayslake
    I did put the o rings back but maybe I hit one or something. It looks like it is coming or right be for the TB and the supercharger bolt together. Its not a little/slow drip it shots out all over to. What plugs are you talking about on the TB?
  7. #7 Re: bad start
    Grayslake
    well i got it to run better had the wires messed up. its not leaking as much coolant but its burning it. so now i have to find out why the supercharger gasket didn't seal? any ideas why it wouldn't?
  1. Car won't start!!!!!!!!
    By hawk611 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2009, 10:50 PM
  2. The Start
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:43 AM
  3. Help car won't start
    By gtora69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 05:48 PM
  4. Start Me Up!!!
    By coolken84 in forum General Tech Discussion
    Last Post: 02-14-2009, 01:47 PM
  5. Let me start over
    By vermsta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-29-2008, 06:02 PM
