i feel like a total idiot for having to ask this but how do you remove the front valve cover do you have to take the motor mount out ? or what? Thanks
Moved this over into the engine section.
You have to remove the mount and the ICM.
To remove the engine mount of which you speak.
* 1. Take off SC belt.
* 2. Take off SC idler pulley with a 15mm wrench or socket.
* 3. Take off SC tensioner pulley with a 13mm or 15 deepwell socket.
* 4. Take off bolt that attaches bracket to head with 15mm deepwell socket.
* 5. Start to take the nut off from the long bolt underneath the coil packs with 13mm deepwell socket (or 15mm, can't remember for sure).
