Thread: Valve Cover Removal
Results 1 to 4 of 4
  1. #1 Valve Cover Removal
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    i feel like a total idiot for having to ask this but how do you remove the front valve cover do you have to take the motor mount out ? or what? Thanks
  2. #2 Re: Valve Cover Removal
    Oklahoma
    Moved this over into the engine section.
  3. #3 Re: Valve Cover Removal
    St. Louis
    sry didn't mean to post in wrong section
  4. #4 Re: Valve Cover Removal
    SE Level Member snow99dohc's Avatar
    Rugby ND The Center of Nor. Amer.
    You have to remove the mount and the ICM.
    To remove the engine mount of which you speak.
    * 1. Take off SC belt.
    * 2. Take off SC idler pulley with a 15mm wrench or socket.
    * 3. Take off SC tensioner pulley with a 13mm or 15 deepwell socket.
    * 4. Take off bolt that attaches bracket to head with 15mm deepwell socket.
    * 5. Start to take the nut off from the long bolt underneath the coil packs with 13mm deepwell socket (or 15mm, can't remember for sure).
    2003 Pontiac Gran Prix GTP-Thrasher CAI, 180 degree t-stat, AL 104's, ZZP/PT Pcm, ZZP Stg 1 HV TB, ZZP headers, 3'' custom catback, magnaflow mufflers, 3.4''
  1. Key Removal Solenoid
    By thermanlee in forum General Tech Discussion
    Last Post: 08-12-2012, 01:40 PM
  2. Valve cover gasket replacement
    By Burgundyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 07:06 AM
  3. Lets see your painted/smoothed/custom front valve cover
    By snow99dohc in forum Visual/Body Modifications
    Last Post: 06-22-2008, 11:37 PM
  4. Axle removal problems...please help!!
    By copgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2008, 02:59 AM
  5. Finished Valve Cover
    Last Post: 02-01-2008, 06:10 PM
