Thread: coolant smell
Results 1 to 14 of 14
  1. #1 coolant smell
    SE Level Member Charged97's Avatar
    ATLANTA
    ok here s the deal it has a new raidator and new hoses btw its a 97 when i stop my car after driving home from work i can see smoke coming out on the passenger side by the head lights excaping from there so i lean over and smell it its deff coolant but i cant find the leak were are some places it would leak from on the passenger side and burn
  2. #2 Re: coolant smell
    TDCRacing
    Guest
    cHECK AND MAKE SURE THE COOLANT OVERFLOW LINES ARE ON GOOD. Also check the actual radiator. New parts somtimes go bad and are not made correctly.
    Usually when they go bad it is on the ends where they weld the tanks on. so look there first.
  3. #3 Re: coolant smell
    Jan 2009
    Paducah Ky
    What he said above...sometimes the hoses need to be retightened. I would check them all, just in case. Also check around the water pump for signs of coolant. It could be coming out of the weep hole on the bottom of the pump. Not likely the way you describe it but still a good idea to check.
  4. #4 Re: coolant smell
    SE Level Member jersey jok3r's Avatar
    Northern New Jersey
    I have the same exact problem on mine but its coming from the driver side without smoke though. I just did a bunch of mods to my engine so maybe I didn't reattach a hose tight enough or would it be a different story because its on the other side of the engine?
    Ported Outlet/Inlet,3.4 pulley,ZZP PLOG, ZZP 3"DP,U bend delete, K&N CAI, ZZP wires,high-flow CAT, ZZP TB Spacer, Autolite iridium 104s,180tstat, OVERKILL PCM, Borla Cat Back system, Black Halo HIDS, Phantom autometer gauges
  5. #5 Re: coolant smell
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Wow what an old thread dude. lol. But check where ur thermotat housing is. Did u bleed the system? might have a leak at the hose to the bottom on the PCM side.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  6. #6 Re: coolant smell
    Northern New Jersey
    I don't think its that, the car is not running hot at all and so far I don't think its leaking any anti freeze. I'm gonna let the car sit a little bit and see if it drips but I did just replace the pcm and the tstat but like I said the car is not running hot or leaking so far its just smells like anti freeze is burning on the driver side.
  7. #7 Re: coolant smell
    Charles City, IA
    There should be no gasket for the T-stat just an O ring.
    SMGPFC Two Nipple General
  8. #8 Re: coolant smell
    Northern New Jersey
    bbptech you were right I just checked and noticed right on top of the block its not leaking bad but its definetly moist and the smell is directly coming from there. Its either that or the tb spacer I just put in but either way I found the problem, thanks man I appreciate it, I'm loving that blacked out gp you got too
  9. #9 Re: coolant smell
    Most likely the TB spacer. I'd suggest blocking the coolant flow into the UIM/Charger to stop the issue.
  10. #10 Re: coolant smell
    Northern New Jersey
    yeh thats what i'm gonna do, how far away is your purpledino from NJ?
  11. #11 Re: coolant smell
    Northern New Jersey
    it was the t stat all I had to do was tighten it, thanks again for the help guys
  12. #12 Re: coolant smell
    for GT's theres not supposed to be a gasket yet apparently GTP's have gaskets.
    This is what my computer at work tells me which is known to be wrong all the time.
  1. Which coolant to use...
    By Rickochet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:34 PM
  2. Burning Oil Smell
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2008, 01:07 PM
  3. fuel vapor smell....
    By Vegas~Blown in forum General Tech Discussion
    Last Post: 09-01-2008, 10:45 PM
  4. Air condition/vents smell when turned on! How do I fix?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-08-2008, 12:54 PM
  5. 2000 GP SE rich fuel smell out of vents this morning.
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-29-2008, 08:54 AM
