Thread: L32 vs L67 Front cover
Results 1 to 4 of 4
  1. #1 L32 vs L67 Front cover
    GT Level Member pontiackid's Avatar
    KCMO
    Any differences between the balancer, frontcover, timing chain, oil pump or anything? Any size differences to add clearance for a double roller?
    TIA
    -KT
  2. #2 Re: L32 vs L67 Front cover
    Portland Oregon
    No diff that I know of. Just do two front cover gaskets to get clearance the double roller
  3. #3 Re: L32 vs L67 Front cover
    Or machine the gear Kyle...thats what I'm doing
  4. #4 Re: L32 vs L67 Front cover
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Just get the Pump Cover machined .020 and ull be fine for a Double Roller. if u do decide to run 2 gaskets instead, then make sure they are the paper ones and not the blue metal ones. The Blue metal gasket is .010 thinner than the paper one.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  1. Front bumper cover
    By mminchau in forum Visual/Body Modifications
    Last Post: 07-27-2009, 04:54 PM
