Thread: JP Double Roller crank gear chamfer
Results 1 to 9 of 9
  1. #1 JP Double Roller crank gear chamfer
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Ok so i have the JP Double Roller that i installed a couple of weeks ago. Ive been slowly putting my build together and have been contemplating what to do with it. I was deciding to either sell it and get a Rollmaster Double Roller or have the Chamfer machined on the crank gear. I have decided to get the chamfer machined more so the whole stretching chain issue would be resolved and i can live freely without ever having to deal with that crap. But with that being said, what would it have to be machined to for the chamfer to be corrected? like how much has to be machined off?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: JP Double Roller crank gear chamfer
    someone correct me if im wrong, but if you bought it recently then they are the same thing no matter which one you buy.
    however, the crank gear no one can tell you how to machine it. every crank is machined to telerance, but its not like they are all the same. you have to match the chamfer on YOUR crank to get it right and make sure it fully seats. its also not so much that it fully seats, but that the chain itself runs completely parallel to the motor and wont run at and angle. if it does the chain will eat itself and eventually break.
    here is a GREAT thread to read on the double rollers:
    ClubGP Message Forum troubleshooting
    im sure youve seen it, but if you havent then make sure you read it. also, another person that might be a good resource for you to contact is GR8RacingFool. he knows his stuff and can probably push you in the right direction.
  3. #3 Re: JP Double Roller crank gear chamfer
    Bastard Reptile's Avatar
    Kansas City, MO
    It "normally" doesn't run that much to have it machined. The best thing to do, is take the double roller gear, and then your stock gear to the shop, and tell the guy to make this (double roller gear) to look like this (stock gear). Make sure he see's what you're talking about, and then it's a matter of a few minutes.
  4. #4 Re: JP Double Roller crank gear chamfer
    Quote Originally Posted by Reptile View Post
    true that. forgot that its as easy as matching the stock gear. you still need to make sure it runs true though. not sure if anyone has ever ran shims or if it was ever necessary.
  5. #5 Re: JP Double Roller crank gear chamfer
    Kansas City, MO
    I'm not sure, the two that I've had done seem to be pretty darn close. Of course, as long as I'm running the "little" springs, I'll never do the double roller again.
  6. #6 Re: JP Double Roller crank gear chamfer
    hey by the way reptile u got PM from me. And the whole taking the stock gear in with the double roller gear is good idea ill do that for sure.
  7. #7 Re: JP Double Roller crank gear chamfer
    Kansas City, MO
    Quote Originally Posted by bbptech View Post
    Yeah, got it and replied. Got about 2 weeks of PM's that I'm going through, and it's taking me a little bit to get them all answered.
  8. #8 Re: JP Double Roller crank gear chamfer
    That is what I was wondering since after getting my RM last night as long as the stocker and the RM gear are the same height sitting next to each other then they are good to go...right?
  9. #9 Re: JP Double Roller crank gear chamfer
  1. Machining double roller crank gears (pics + vid)
    By GR8racingfool in forum How To Write-Ups/Tech Tips
    Last Post: 07-27-2009, 08:18 AM
  2. issues with JP double roller crank gear removal
    By impalamike3800 in forum General Tech Discussion
    Last Post: 07-25-2009, 08:58 PM
  3. which double roller
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 06:52 PM
  4. Timing a double roller?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2008, 06:57 PM
  5. Double roller issues
    Last Post: 05-03-2008, 09:07 AM
