Thread: Leaking Antifreeze
Results 1 to 13 of 13
  1. #1 Re: Leaking Antifreeze
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    Thanks! I got your first reply and went to the dealership. It's $12. Thanks!!! Does it just pop off and on?
    I had to come back home I forgot my card. I'm gonna go get it then come home and fix it.
  2. #2 Re: Leaking Antifreeze
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by GTPluv View Post
    From memory;
    You should be able to remove or maybe even loosen the alternator enough to get that elbow out. Just be careful not to break the other elbow that you can't see. The last one I did was on a Bonne.
    Hopefully someone that has done a lot of these will step in otherwise I'll see if I can dig up a How-To for you.
    I can't come up with anything for just the elbow. Too bad this wasn't' tomorrow. My son and I are tearing his GTP apart tonight to replace the LIM and VC gaskets, coolant elbow, rockers, injector orings...etc... not going to help you today though,
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  1. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
  2. Fluid Leaking out of Axle Seal Still
    By Metallistar in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 04:39 PM
  3. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
