Thread: How to remove the supercharger ?
Results 1 to 20 of 22
  1. #1 How to remove the supercharger ?
    GXP Level Member ryangtp89's Avatar
    Maine
    Hey guys im taking off the supercharger to get ready to sell, could you guys tell me how to get it off. Soo far i got a bunch of bolts off around it but i cant seem to get it off completly. soo i need some help.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Are you sure you got all of the bolts out? Long one that goes through the snout? I didn't have any problems removing mine, but apparently there is at least one bolt that many people miss.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    are you sure you have all of them ?
    There's one that's by the EGR bracket people miss sometimes. If you're 100% sure everything is unbolted use some force to get that sucker off. Sometimes they're stuck on pretty good.
    Maine
    Oh i didnt take the bolt off that goes through the snout, Do you have to take off the pulley or anything like that.
    Oklahoma
    I thought we had a write up on how to do all that, but it appears that we do not. That said, any how to on installing a cam, replacing the LIM gaskets and so forth will have all the info you need.
    But, Indeed is correct there is one bolt that everyone seems to miss but I cannot remember which it is, but I would suspect as well the one in the snout.
    Maine
    how do you get at the bolt in snout, its too dark out now to work anymore and im itching to get it off, soo ill be up soon as it turns light out to take it off.
    Oklahoma
    You should be able to get it off without any trouble. I know this because I had to pull my snout off to replace the coupler a couple of years ago, so I know you can separate the snout from the rest of the blower. Looking at the blower from the passenger side on the left side of the snout is a bolt that holds that down and its the only one there.
    Maine
    ok ill try tht tomorrow, and you guys will be seeing me putting up an add for the supercharger soon after, i just dont know how much yet, it runs perfect.
    St Louis MO
    I didn't go look, but you don't have to take anything else off. Just look for a bolt or two going through the snout base into the LIM vertically like the rest you removed. As mentioned above look for the one next to the EGR as well.
    2010 Camaro SS LS3
    St Louis MO
    perhaps a picture of the s/c gasket will help
    How to remove the supercharger ? Attached Images
    2010 Camaro SS LS3
    Maine
    well that must be the last bolt cause i tryed prying it but it wont budge soo ill check for that last bolt tomorrow morning.
    Maine
    oh that defently helps thank you
    SE Level Member NME's Avatar
    just count the number of bolts you pulled off..
    9" k&n Cone - N* - DOHCZ34 Ported Gen V - ported LIM - XP cam - 90# springs - 3.3 mps -Wraped pacesetter headers - Fuel rewire - waiting on new IC's!
    Maine
    yea i was thinking about tht im gonna count them tomorrow, now is all the bolts that hold how the s/c the same lenght and what not.
    SE Level Member a_v_s's Avatar
    PacNW
    Quote Originally Posted by ryangtp89 View Post
    IIRC, most of them are, but the one that goes near the EGR looks different and is longer as well, because that's what the EGR heat shield mounts to.
    Maine
    ok then
    St Louis MO
    btw if you are sure you have all of the bolts out, and it still won't budge, try spraying some brake cleaner around the gasket area and let it soak in for a while. I think I may have used WD-40, but you get the idea. Tapping a plastic putty knife or scraper under the supercharger housing may help get you started. Of course you are probably finished by now.
    2010 Camaro SS LS3
    Maine
    haha not yet, i have been super busy, Ill try the wd40 in a little bit, i think theirs one more bolt idk yet.
  19. #19 Pulley diagram
    Dallas TX
    I have a pulley that I think is out. Its just below and to the left of the front belt tension (super charger belt). And it is not grooved for a belt but is smooth. It has no bolt on the front, looks like a star head bolt. Not sure what it is. Any help would be appreciated. Thanks
  20. #20 Re: Pulley diagram
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by butch View Post
    Apparently your not very observant.... or bright for that matter.
    Try posting your own thread about your issue, rather than posting in a thread that was created, and died, almost two years ago.
  1. L26 intake v.s. Blocked off supercharger
    By Andrew_99GTP in forum Turbo
    Last Post: 11-03-2008, 09:05 AM
  2. How to remove the ashtray?
    By IndeedSS in forum General Tech Discussion
    Last Post: 01-20-2008, 06:44 PM
  3. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
