Thread: which is better on intakes?
Results 1 to 9 of 9
  1. #1 which is better on intakes?
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    i have a 3" fwi rite now on my car. would it be better 2 have a 4" intake with a big @$$ filter on it instead not in the fender well? so basicly is it better 2 have a 3" fwi or a huge 4" under the hood?
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  2. #2 Re: which is better on intakes?
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    4 inch setup with bigger filter is better because of less resistance and restriction. 3 inch FWI is better for idling in traffic because its sucking it cooler air, but other than that not really better.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  3. #3 Re: which is better on intakes?
    GEORGIA
    so i guess i need to go with the 4" then. i mite just build 1 2 go in the fender as well. but i think i'll gain more with just a 4" pipe and a huge filter under the hood.
  4. #4 Re: which is better on intakes?
    Charles City, IA
    make something like this
    SMGPFC Two Nipple General
  5. #5 Re: which is better on intakes?
    GT Level Member EmEaston24's Avatar
    Pittsburgh
    ^^ thats how mine is. it doesnt acutally go down into the fender. i still get cold air tho when im drivng.
  6. #6 Re: which is better on intakes?
    GEORGIA
    yea ima do that then. so it should help it run a tad faster and better? will it help with kr?
  7. #7 Re: which is better on intakes?
    Jan 2009
    Tallahassee, FL
    I went from a 3.5" FWI to a K&N on the TB and didn't notice much of a change other than the blower was a little louder. Still 0* KR on a 3.4 and stock tune.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  8. #8 Re: which is better on intakes?
    May 2008
    McHenry IL
    whats ur mods sand for no tune and no KR?
  9. #9 Re: which is better on intakes?
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by GTPJOE90 View Post
    plog, 3" catless DP, AL 104s, ported blower, 3.4 press on, shift kit, 180* thermo. I will get KR if my temps go above ~200, I have a switch for the fans if I get stuck in traffic to keep them at 180. Even when I did get KR it was only 1*-1.5*.
    I also have a IAT from Green Bastard which may help out some.
    77 Morris Garage B
  1. Air Intakes
    By josemolina2008 in forum General Tech Discussion
    Last Post: 08-28-2009, 07:43 PM
  2. intakes
    By MakeitLouder97 in forum General Tech Discussion
    Last Post: 07-25-2009, 11:43 AM
  3. intakes
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2009, 10:31 PM
