Thread: Help asap!
Results 1 to 20 of 22
  1. #1 Help asap!
    May 2008
    McHenry IL
    almost done with engine swap its coming along well!!! bottom line is we are stuck n the power steering pump and lines are being a pain in the a55. is there a easy way of doing this i have 2 people including myself working on this after we install the pump all we have to do is the alt bracket alternator a few connectors and then add fluids!!! SHE WILL LIVE TODAY! is there any hints or tips to doing this its not lining up and the hoses are sorta binding or something its a big pain in the a55. all help is appreciated thank you!
  2. #2 Re: Help asap!
    Banned - Busted For Scamming
    Feb 2009
    hand thread them in and tighten it down, there is only one hard connection lol
    When you gonna come off those damn heads?
  3. #3 Re: Help asap!
    May 2008
    McHenry IL
    i didnt take any of the lines off. and its being a pain in the a55 to line up with 2 people...
  4. #4 Re: Help asap!
    Feb 2009
    well whats the problem then? you trying to line up the power steering bolts?
  5. #5 Re: Help asap!
    May 2008
    McHenry IL
    yes! its retarded ha
  6. #6 Re: Help asap!
    May 2008
    McHenry IL
    ahhhhhhhhh im so going to throw something ha
  7. #7 Re: Help asap!
    May 2008
    McHenry IL
    ughh still a pain in the ass!
  8. #8 Re: Help asap!
    May 2008
    staten island,NY
    when i took my pump off i jacked up the car and took the passenger wheel off. made the bottom bolt much easier to get it
  9. #9 Re: Help asap!
    Feb 2009
    u run that spacer yet quick lol
  10. #10 Re: Help asap!
    May 2008
    staten island,NY
    its going on as soon as ZZP ships me my bolts lol
  11. #11 Re: Help asap!
    Joe.. one thing to keep in mind is if the motor is sitting back (no dogbones connected) the angles will be off and it may be tougher.
  12. #12 Re: Help asap!
    another thing to keep in mind is stop being a woman. if the power steering pump is the only thing holding you back then you clearly have no idea how to work on a car.
  13. #13 Re: Help asap!
    Wausau, WI
    LMAO.... I assume that you got the thing on by now? Is it alive?
  14. #14 Re: Help asap!
    Wichita
    Keep up the hard work!
  15. #15 Re: Help asap!
    May 2008
    McHenry IL
    i took a break last night i was pissed off and bill good point ill throw the bones on. but yeah i had to work and just got home from shipping some goodies i sold from my old block. anyways. pull engine forward to normal position DONT get pissed off and throw a cresent wrench across the garage... gotcha LMAO it took all of 5 minutes to mount the engine to the trans and the motor mounts everything was going super smooth. then this pump..... hahaha
  16. #16 Re: Help asap!
    Wichita
    Quote Originally Posted by GTPJOE90 View Post
    Heh heh I know your pain all too well. It's worth it when your finally done
  17. #17 Re: Help asap!
    May 2008
    McHenry IL
    im going to get in the garage in about a hour and tackle it tonight hopefully ha wish me luck ha i was talking to my neighbor and urlosn they both said just tough it out and yes its a pain in the ass ha
  18. #18 Re: Help asap!
    SE Level Member drewz313's Avatar
    Morgantown, wv
    I wish I could help. I just put mine on and had no problems. Do you have to Alt bracket on or off?
  19. #19 Re: Help asap!
    May 2008
    McHenry IL
    yes i do its like the power steering lines are catching on soemthing? lol idk its gay!
  20. #20 Re: Help asap!
    Charles City, IA
    Look at them and see if they are.
    SMGPFC Two Nipple General
  1. Need Help ASAP!!
    By 98gtpne in forum General Tech Discussion
    Last Post: 10-07-2009, 11:15 AM
  2. help asap please
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-23-2009, 08:24 PM
  3. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
  4. I need a l67 asap !!!!!!!!
    By hatrain32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 09:25 AM
