Thread: Smog pump delete?
Results 1 to 12 of 12
  1. #1 Smog pump delete?
    SE Level Member 2001GTP's Avatar
    Apr 2009
    Phoenix, AZ
    I am lucky enough to have a stinking smog pump according to my buddy's dhp tuner. Also the sticker under the hood says I'm CA emiisions compliant. Will it affect my AFR reading on a wideband and where is the thing so I can remove it, if it does affect my AFR readings.
    3.6", 3" Downpipe, K&N CAI, 104's, PRJ Tune, P-Log, 180 t-stat,Res delete, wideband, boost gauge. 14.11" @ 99.5
  2. #2 Re: Smog pump delete?
    Jan 2009
    Tallahassee, FL
    We have a smog pump?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Smog pump delete?
    Apr 2009
    Phoenix, AZ
    The CA cars do. AKA air injection pump.
  4. #4 Re: Smog pump delete?
    Get rid of that shiz...just rip it out and cap off the vacuum lines attached to it...then again...I've never seen a L67 car with a smog pump so maybe a pic would help..
  5. #5 Re: Smog pump delete?
    May 2008
    staten island,NY
    my car has one too i got rid of it all and it never triggered a ses light so i left it alone
  6. #6 Re: Smog pump delete?
    Banned - Busted For Scamming
    Feb 2009
    Air injection pumps usually inject the air downstream in between the two beds of the cat. Removing it wont affect your a/f readings. Why would you want to remove it though? Its electric, correct?
  7. #7 Re: Smog pump delete?
    Apr 2009
    Phoenix, AZ
    I don't want to remove it if it doesn't affect my AFR readings. I'm getting ready to install my wideband and want to make sure the pump won't throw my readings off.
  8. #8 Re: Smog pump delete?
    Charles City, IA
    It wont change the readings. You have to have your wideband before the cat.
    SMGPFC Two Nipple General
  9. #9 Re: Smog pump delete?
    May 2008
    staten island,NY
    the air pump feeds from behind the drivers foglight is the pump then it runs up the side of the trans to the back of the rear exhaust manifold. it uses fresh air to neutralize the toxins from the exhaust to keep the life of the cat. i got rid of all my stuff cause now i run headers, and i never had a cat.
  10. #10 Re: Smog pump delete?
    Charles City, IA
    If it injects air into the rear mani then yes you need to delete it or you will run lean.
  11. #11 Re: Smog pump delete?
    Apr 2009
    Phoenix, AZ
    Thats what I thought. P.S. I have no cat.
  12. #12 Re: Smog pump delete?
    Charles City, IA
    Yup pull the pump
  1. Smog pump question.. please help.. I'm having so much trouble with this thing.
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 04-01-2009, 11:32 PM
  2. delete?
    Last Post: 07-27-2008, 03:04 PM
