Thread: Engine has no power
Results 1 to 19 of 19
  1. #1 Engine has no power
    canada
    Its a 99 Pontiac Grand prix GTP supercharged. It changed all of a sudden with the load noise and then barely made it home.
    It started about 4 weeks ago. Engine light came on telling me cylinger 1 misfire after a hard weekend of driving. As long as I didn't stomp on it you wouldn't know there was a problem. When you went to pass, car would not accelerate. I changed the spark plugs, wires, air/fuel filter and light went out but power was the same. Going home one day I stomped on it and then there was a loud growl and then the car would only go 30 miles an hour. Once you RPM's reach 3500, the car just dies. There was a grinding noise from the supercharger so I changed the supercharger with a rebuilt and still the same. Changed camshaft sensor,crankshaft sensor, and mass air flow sensor and nothing has changed.
    I have disconnected O2 sensors and it does not make a difference. I have scanned it many times and it usually just comes up as mis fires. It seems to idle fine but as soon as you rev it up over 3000 it begins to die and the back on the motor smokes.
    Please help
    Thanks
  2. #2 Re: Engine has no power
    SE Level Member ChvyTrcksFrdScks's Avatar
    Jul 2008
    Kalamazoo, MI
    Well, whats the make, model and year; and is there anything else on the car turning on or acting weird? I need to know as descriptive as possible, exactly what the car is doing and if possible the history if anything significant happened to it in its lifetime. Thanks
  3. #3 Re: Engine has no power
    canada
  4. #4 Re: Engine has no power
    SE Level Member E90 87SS GTP's Avatar
    NJ
    did you hook it up to a computer? ignition module? engine rough at idle? supercharger still making grinding noise?
    I think local AAP has computers they can lend you.
  5. #5 Re: Engine has no power
    Jul 2008
    Kalamazoo, MI
    What have you checked, please list everything you can.
    2002 Pontiac Grand Prix GT
  6. #6 Re: Engine has no power
    canada
    Thanks
  7. #7 Re: Engine has no power
    canada
    Are these symtoms of a timing chain which has jumped?
  8. #8 Re: Engine has no power
    Jul 2008
    Kalamazoo, MI
    ok, so what have you checked? I need to know what is working properly so I can help you narrow it down to what it might be.
  9. #9 Re: Engine has no power
    Jul 2008
    Kalamazoo, MI
    No probably not.
  10. #10 Re: Engine has no power
    Please hook the O2 back up. That will make diagnosis harder. All the misfires point to an engine issue. Check the oil level and look at the oil for any silver streaks etc.
  11. #11 Re: Engine has no power
    Guam
    Get a GM scan tool and scan it...
  12. #12 Re: Engine has no power
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Do you still have a catalyic converter? Sounds like a clogged cat to me. Have someone revv the car while you hold your hand in front of the muffler. If you barely get any gases or its really cool then your cat is bad. If you had a timing chain jump a tooth then it would run like **** all the time. Just think about the smoke at the back of the engine. Sounds like congestion because even with 5 cylinders you should be able to rev it over 3 grand.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  13. #13 Re: Engine has no power
    Jul 2008
    Kalamazoo, MI
    He's right, My converter has melted before and if that's the case, then once u replace it your car will run great.
  14. #14 Re: Engine has no power
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    Does your TCS light come on? I had the same symptoms like no power after 3500rpm and such, and after repairing the shorted TCS wire, my GP worked like a charm.
    "Cry Havoc! And Let Slip the Dogs of War!"
    Black 2000 GTP: 3.4" Pulley, Resonator/U-bend delete, 180 T-stat, Tuned PCM, Thrasher Intake, Larger Radiator, 17" Konig Tantrum Wheels, Red Air Dams. Coming Soon...Projectors, Lighting Mods, Transmission Cooler, Black Rims, Tinted Tails and hopefully Headers
  15. #15 Re: Engine has no power
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    its the cat.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  16. #16 Re: Engine has no power
    Charles City, IA
    load noise or loud noise? Where any of the plugs bent when you pulled them out? It if changed all of a sudden with a load noise your piston could be screwed on the cylinder that is misfiring.
    SMGPFC Two Nipple General
  17. #17 Re: Engine has no power
    canada
    Thanks to everyone's input, my car is still not running. I am going to disconnect the converter and go from there to start. If no success, I am going to start on the timing chain . Does anyone know of a good web site for directions how to change a timing chain on a 99 grand prix?
    Thanks Again
  18. #18 Re: Engine has no power
    Apr 2009
    Maine
    Loss of power under load sounds like it could be failing coil pack(s) to me. As for grinding noise, did you check the pulleys? Could be worn bearings.
    I just had a couple pulleys replaced recently and at least one was making a mild grinding noise. It wasn't too noticeable except when I lifted the hood, but I suspect it would have gotten much worse, had I not had them replaced.
  19. #19 Re: Engine has no power
    KS
    Sounds similar to what happened to my bro-in-laws Monte Carlo a week ago. It ended up being the cat. The dealership replaced it for free since he was under 80k miles.
  1. reduce engine power / service traction system
    By p5773566 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 06:56 PM
  2. reduce engine power warning
    By rochaedkj in forum General Tech Discussion
    Last Post: 07-12-2009, 06:24 PM
  3. No engine power above 2-3K?
    By scottm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2009, 02:58 AM
  4. "Reduced Engine Power" message
    By TomDaBomb2u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2009, 11:00 PM
  5. Reduced Engine Power
    By donpedro_81 in forum General Tech Discussion
    Last Post: 09-22-2008, 07:20 AM
