Thread: Harmonic balancer question
Results 1 to 4 of 4
  1. #1 Harmonic balancer question
    SE Level Member drewz313's Avatar
    Morgantown, wv
    I bought a used engine from a junk yard out of 2000 park avenue its a 3.8 supercharged. The junk yard says you need to change the oil pan the pick up tube and the harmonic balancer. The oil pan makes sense and the pickup tube. But not the harmonic balancer. I called advance auto and they couldn't find a part number for the harmonic balancer for a 2000 park avenue. Anybody know if there is a difference?
  2. #2 Re: Harmonic balancer question
    its the same as far as how it works. if its different as in being the same as an h-body balancer (bonneville) then its actually better.
  3. #3 Re: Harmonic balancer question
    I'm with Bio. I've never changed a balancer when swapping. Physical size etc is the same.
    You need to swap the pan due to the aluminum w/o mount at that end vs your mount. And the pickup tube is part of the pan the way I see it. Might be shorter/longer for the alum pan.
    Check TC size to ensure the flywheel bolt holes are the same as they should be. It's a good check though.
    If using stock exhaust manifolds, swap the rear.
  4. #4 Re: Harmonic balancer question
    Morgantown, wv
    I got it in. Everything fits. Had to removal the oil filter adapter and swap it with my other one. Thanks guys
  1. How do you get the crank pulley/harmonic balancer off???
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 11:08 PM
  2. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
  3. Any advice removing old harmonic balancer?
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-09-2009, 06:35 PM
