Thread: dont know what happened...
Results 1 to 12 of 12
  1. #1 dont know what happened...
    GT Level Member BoostedComp's Avatar
    Youngstown
    lately, at times if i go wot my car wont shift into the next gear. it will stay around 5700 rpm's and almost seem like its at a rev limiter. It will shift up if i bring my foot off the gas slightly but other than that it will stay there. I would say it feels like if you were in a manual car and just never shifted up, but like it said it wont go above 5700. I bought an overkill pcm about 2 weeks ago from another member here but it didnt do this when i first put it in so i dont think thats the problem. aside from this problem the tranny shifts through the gears nicely, no slipping or anything. Ever happen to anyone? any ideas? Thanks for any help.
  2. #2 Re: dont know what happened...
    Outer Space
    I personally have not seen this issue, but my first course of action would be to unhook the battery for 15 minutes, and then hook it back up. Then after it relearns everything I would see if it does it again.
    Any SES codes? Do you have a tuner?
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: dont know what happened...
    Youngstown
    no tuner. but also no ses codes. thanks for your input
  4. #4 Re: dont know what happened...
    I'd suggest driving on your old pcm for a week. Even though the issue didn't immediately happen it may be from the pcm. The way to test this is to swap back for a week and see if thw issue still exists. Then you have ruled out the item you recently swapped.
  5. #5 Re: dont know what happened...
    ^^That...but you don't have enough mods to shell a transmission...unless you drive your car like you stole it...if the PCM is crossed off the list you might try a pan drop.
  6. #6 Re: dont know what happened...
    A stock car on stock programming can kill a trans. Remove abuse items, most of the torque management and I'd think it would be pretty easy to beat one into submission.
    At least the way I drive.
  7. #7 Re: dont know what happened...
    Youngstown
    thanks for the input guys. i just had to do some running around for work and it wouldnt do it... i dont think its the tranny either because i dont beat on it from a dead stop... and i dont believe gunning it from a roll is harmful enough to break anything. i dunno im leaning torwards the tune. if i swap pcms how would i be able tell if thats the problem? i think i would be worried to go wot on my stock tune with my 3.6 pully. thanks again
  8. #8 Re: dont know what happened...
    Is it a press on or a MPS system? Buy a stock sized MPS pulley, but then again a 3.6" isn't really going to kill you with a stock tune as long as you have supporting flow mods.
    If that is the case then wtf was I doing wrong shelling all these motors LMAO!!
  9. #9 Re: dont know what happened...
    Youngstown
    its a mps system... anyone have one? dont feel like spending 60 bucks for a stock size pulley. maybe ill just see if i can get another tune from will and see if it fixes eveything up
  10. #10 Re: dont know what happened...
    What tune is it?
  11. #11 Re: dont know what happened...
    Youngstown
    its an overkill pcm i got from a member on here... so not directly from will
  12. #12 Re: dont know what happened...
    Deeeeeeeeeeeeeeeeeeeeeeeeeeeeeehpeeeeeeeeeeeeeeeee eee
  1. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
  2. Yea it happened again
    By uNda6gT in forum Track Sessions and Kills
    Last Post: 07-28-2009, 10:31 AM
  3. What Happened?
    By BwolfGT in forum General Tech Discussion
    Last Post: 05-14-2009, 05:24 PM
  4. What happened?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-06-2008, 10:47 PM
  5. Something off happened the other day...
    By Zef_66 in forum General Tech Discussion
    Last Post: 04-23-2008, 08:45 PM
