Thread: Fuel rail mods for intercooler?
Results 1 to 11 of 11
  1. #1 Re: Fuel rail mods for intercooler?
    Wichita, KS
    Quote Originally Posted by webracin View Post
    BEWARE of modifying the stock fuel rail to work with an intercooler. There have been MANY engine fires because of this.
    The only options that are safe in my book are as follows:
    (in order of cost)
    1. fuel injector spacers
    2. Modified fuel rail from W Body (these are braised, and dont use any rubber hoses)
    3. ZZP Fuel Logs
    4. PRJ Fuel rails
    If you need some pictures of what happens when you modify a fuel rail, I think I can find some pics of a friend of mines car.
    webracin
    X2 on this post. I agree with it 100%.
    Stock fuel rails are fine and not restrictive, so there is no logical reason to change them out unless your lifting the supercharger/intake up for the installment of a IC.
    ~F~
  2. #2 Re: Fuel rail mods for intercooler?
    GTP Level Member David99GTP's Avatar
    Florida
    Logical whats that? Know whats crazy, I changed mine for appearance only LOL. I want to show off my SC when you polish it
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  3. #3 Re: Fuel rail mods for intercooler?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by David99GTP View Post
    yea and that coming from someone who is big on cometics
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: Fuel rail mods for intercooler?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I have mixed feelings on modded fuel rails but it is certainly the cheapest route. Im not too crazy about the ones on the market so I made my own setup for a customer on the last IC install I did last year and it turned out really nice. I too brazed the lines and ran everything under the throttle body so there are no lines on the front of the engine. I also mounted the pressure reg on the back side as the others are setup but its looks much cleaner this way, especially with everything being black. The big problem with this particular car was there wasnt room for lines to run over the top of the blower as it was already hitting the hood, ram air type hood, and had craddle spacers so we could shut the hood! I had to grind section of the blower and even mill down the area where the vacuum port bolts on top just for some extra clearance. What a pain but it turned out nice. We installed an older ZZP stage 1 intercooler on a good friends car back in 03 at the time I think Thrasher had the only aftermarket rails so we followed ZZPs instructions for modding the stock rail and it has never had a problem the whole time but I do agree that this method can have potential fire issues. The other problem is that bone stock cars catch on fire from the orings in the fittings be bad alone. Most of the junk yards around here have a handful of burn victims from this happening and wow does it get ugly sometimes! Something else I just thought of as I have only installed one SS intercooler.... IIRC you only have to cut one or two sections of the line and re-bend it a bit and it works fine just adding one new piece of line. If the ends were flared it would really add a good bit of security but the modded rails or billet rails really do look a lot nicer.
  1. Short Stack Intercooler [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-30-2012, 04:20 PM
  2. Intercooler Flow???
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 08:45 PM
  3. Intercooler radiator
    By silvermistGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2008, 12:29 PM
  4. Intercooler Spray Bar Kit...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 12:18 AM
  5. best first mods to do
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2007, 07:50 AM
