Thread: If you recently bought an aftermarket radiator from ZZP or W-Body store
Results 1 to 7 of 7
Threaded View
  1. #1 If you recently bought an aftermarket radiator from ZZP or W-Body store
    SE Level Member Gandalf's Avatar
    North Florida
    Please check it, they sent out a several that were just stock replacements and not the thicker core ones!
    It was a supplier error.
    I bought one from ZZP in December and finally got to do the install last Saturday, ripped the car apart, opened the box and noticed that it was exactly the same width 7/8's"
    Posted on CGP and Zoomer said to send it back for replacement.
    So I had to reassemble the car and will have to do it all over again
    On a side note, ever since I bought the car (brand new) I noticed a vibration when the second cooling fan kicked in, dealer said it was normal. After looking at it while I had the assembly out I noticed that it was defective and had a chunk missing from the outer wheel part of the fan
    Thank God for Ed Morad, he sold me a complete fan assembly for a couple of dollars more than I coulda got a fan blade for. Which is good because after 4.5 years of heavy use combined with blade being off balance I am sure that the fan motor bearing is about shot.
    For all you 03 owners, we don't have a coolant level sensor so if you get an after market radiator you will need to find a way to plug the hole!
    I picked up an old sensor just to fill the hole.
    2K3 GTP Redfire Mettalic,1.95 RR's,90#Springs, Tog's, RAT TB,JMB FWI,PRJ Wires,MSD Coils, AGX Struts & Vogtland Springs, Next Level Front+Rear Swaybars & STB's,MOOG Endlinks,17" SLP Rims, F-Body Brakes, Ractive Oval Tips,Perf Shift Added, Powertuner,WB O2,Lucas Flowmatched 42.5 injectors, Mag Snout w\3.4
  1. Thoughts on Grand Prix Store Cam 1 ?
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2008, 04:10 PM
  2. Transmission lines to radiator
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2008, 10:45 PM
  3. Aftermarket Exhaust
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 12:18 AM
  4. What aftermarket convertor do you run?
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-03-2008, 12:20 PM
  5. GPF store....DONE!!
    By UR LOSN in forum Forum Bugs/Suggestions
    Last Post: 01-01-2008, 02:10 PM
