Thread: KR Help!!
Results 1 to 20 of 22
  1. #1 KR Help!!
    SE Level Member 2001GTP's Avatar
    Apr 2009
    Phoenix, AZ
    First off here are my current mods..... 3.4", 180 t-stat, 104s(new), 2.5 catted DP with u-bend and resonator delete, P-log, Custom DHP PCM. Anyways with the "standard" DHP PCM I was hitting as high as 10 degrees of KR. I know!!! So we dropped the timing back to stock. Still seeing as high as 6 degrees of KR. Added 10% more fueling and still getting bad KR. The IPWs are high as hell, 18 to 19 and the IDCs are as high as 90. Basically my injectors are maxed out if not beyond some. I replaced the front O2 to no avail. My LTFTs are around 7 and O2s are 900 to 910. I'm buying a wideband tomorrow and haven't gotten around to check fuel pressure yet. I guess I'm just looking for any ideas on what things to check. Thanks!
    3.6", 3" Downpipe, K&N CAI, 104's, PRJ Tune, P-Log, 180 t-stat,Res delete, wideband, boost gauge. 14.11" @ 99.5
  2. #2 Re: KR Help!!
    Portland Oregon
    Wow, that's a LOT of kr for that setup. Why didn't you get the 3 inch dp? 2.5 are great for n/a. If you can figure it out soon get that pulley off of there until you find out what's going on.
  3. #3 Re: KR Help!!
    Charles City, IA
    See what your a/f is with the wideband. You want to shoot for about 11.5. Do you have a mps or press on pulley. I would bump up the pulley size until you can figure out your tune. Also drop some timing out to help take out the knock.
    SMGPFC Two Nipple General
  4. #4 Re: KR Help!!
    Apr 2009
    Phoenix, AZ
    Timing is back at stock. Its a press on pulley. I don't think its in the tune because my guy who tunes loaded the fueling tables basically as much as he could. Also it has a brand new fuel filter. I'm just hoping its a tired fuel pump. Also, the car isn't going to be driven until its figured out.
  5. #5 Re: KR Help!!
    Charles City, IA
    Pull timing further than stock. If it is still knocking. You pull timing until the car stops knocking. Loading the fuel tables it not the proper way to do it either.
  6. #6 Re: KR Help!!
    Apr 2009
    Phoenix, AZ
    I understand pulling the timing even more. I'm just curious as to why with my setup I am getting such bad KR. Is there something I'm missing?
  7. #7 Re: KR Help!!
    Charles City, IA
    I am knocking with my mods too. I bet it is something in the tune or there is carbon built up in a cylinder and is creating a hot spot for knock.
  8. #8 Re: KR Help!!
    when are you knocking? how far has he pushed the thresholds for the transmission so that it doesnt pull timing (knock) when youre on it hard?
    i also believe you need a little more flow action (bigger downpipe).
  9. #9 Re: KR Help!!
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    get a 3 inch downpipe. 2.5 is basicley stock since the stock downpipes r double walled on the inside at 2.5, even tho u deleted the ubend and res.
  10. #10 Re: KR Help!!
    screw that DP story...get headers
  11. #11 Re: KR Help!!
    Joliet, IL
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  12. #12 Re: KR Help!!
    Tofu Delivery Boy Lsick7's Avatar
    MO
    Agreed. If money is an issue check out ssautochrome headers for $350. Great replicas of slps.
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  13. #13 Re: KR Help!!
    Donating Users PonchoDvr4Lfe's Avatar
    Feb 2008
    Kent, OH
    Anyways... now that all of you people plugging headers over his current set-up are done.
    Is there anything you can think of that may be giving you false knock?
    04' GP GTP Comp G, 08' G8 GT, 10' Camaro 2SS
  14. #14 Re: KR Help!!
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by PonchoDvr4Lfe View Post
    Running a 3.4 pulley with a 2.5" dp is going to give you most of the KR he sees, headers are optimal on a 3.4 setup. The other KR is from running a car without much of a tune. Open the exhaust a little more and then get your tune figured out...
  15. #15 Re: KR Help!!
    Feb 2008
    Kent, OH
    Quote Originally Posted by FoSHO99 View Post
    I agree that he could use headers, but I don't see the point of everytime there is an KR or exhaust question there is one person who says headers and then everyone on the forum smells it and comes along agreeing with the headers. Thats all I am saying...
  16. #16 Re: KR Help!!
    Charles City, IA
    x2 headers FTW
  17. #17 Re: KR Help!!
    Feb 2008
    I'm thinking you have low fuel pressure if you're getting that high of an IDC with a 3.4 pulley.
    Your LTFT's should be pretty darn close to 0. That can cause a bit of KR even if the NB fueling looks good.
    Check the fuel pressure and let us know what you get?
  18. #18 Re: KR Help!!
    Like I had said...it isn't a plug Poncho...7* of KR is no joke. Headers are one of the BEST ways to kill KR. If it is false...it might be the downpipe making contact with the sway bar or the motor mounts might be shot causing the contact.
  19. #19 Re: KR Help!!
    Apr 2009
    Phoenix, AZ
    Fuel pressure is 48 with key on. 40 when idling. It built kind of slow with the key on only test. I think I'm gonna get a racetronics pump and new 3" DP.
  20. #20 Re: KR Help!!
    you have to see if its dropping on the top end to tell if youre running out of fuel. how are the fuel trims? WHEN is it knocking (top end? mid range? at the shift? etc.)? how much timing do you consider "stock"?
    im thinking the culprit is a crappy tune, then the downpipe, then your car being the opposite of a freak.
