Thread: Supercharger Outler Porting
Results 1 to 3 of 3
  1. #1 Supercharger Outler Porting
    Donating Users
    South Deerfield, MA
    I have another supercharger and am planning on doing the following mods:
    3.4 pulley
    headers
    intake
    plugs
    Tunetimeperformance tune
    considering 1.95 rockers also
    I have access to a bridgeport at work so porting the outlet would cost me nothing except a little bit of time. Is it worth the time for me to do it with this setup? From all I have read, it doesn't sound like I would gain any more power out of it, but I was hoping it might help with keeping the knock down when it is all done. Thanks for any input.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  2. #2 Re: Supercharger Outler Porting
    Banned - Busted For Scamming
    Feb 2009
    No it will help. Just make sure if you are not running an intercooler or havent opened the lim just make it look like this:
    If you plan on running an intercooler AND have opened the lim to match make it look like this:
  3. #3 Re: Supercharger Outler Porting
    Wichita, KS
    If its a GenIII, there is gains in porting and polsihing. GenV, there is no gains, its perfect the way it is and then some.
    Pretty much in a GenIII port job the main goal is to get rid of the snout bolt boss's that poke into/extrude into the outlet, and open it up just a LITTLE. Doing machine work to the "slits" on the out let is up to you.
    I did, and it gave my old GenIII a very unique sound with a engine rev. and under boost. It screamed louder. You can leave the slits alone, and be alright.
    This was my first GenIII rebuild, and the FIRST ever supercharger in the forums anywhere to have a A+ show quality polish job on it. This is what it looked like 3 years after running it when I removed it to install a GenV.
    Inlet was bored to 75.5mm to match the LS1 TB.
    My unique outlet I did on a Bridgeport as well.
    ~F~
  1. Porting Your Supercharger
    By kfish in forum How To Write-Ups/Tech Tips
    Last Post: 02-13-2012, 12:18 PM
  2. Gen V Supercharger Porting
    By ls6velless454 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2010, 05:35 PM
  3. porting
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 03-27-2010, 04:27 PM
  4. Porting Gen 5 M90
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 02:38 AM
  5. porting supercharger specs please
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2009, 01:18 AM
