Thread: Pulleys = what boost numbers?
Results 1 to 20 of 114
  1. #1 Re: Pulleys = what boost numbers?
    SE Level Member Zach3800's Avatar
    Waterloo IL
    i only see 9.8 psi on a 3.4 with a huge cam and high compression
    All you need to know is High compression big a$$ Cam plus blower
  2. #2 Re: Pulleys = what boost numbers?
    Wausau, WI
    Quote Originally Posted by Zach3800 View Post
    And I saw a max of 9.0 with my stock 3.8 setup....obviously it is all about flow....headers, porting, exhaust mods, etc.
  1. Ok here is my dyno. Why aren't these the numbers I should be getting?
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 10:14 AM
  2. Here are Tag Numbers.....
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-24-2009, 02:43 PM
  3. Part numbers
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:50 PM
  4. Numbers
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-10-2008, 02:59 PM
  5. XP cam boost and vac numbers
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2008, 10:54 PM
