Thread: Fuel rails
Results 1 to 17 of 17
  1. #1 Re: Fuel rails
    Banned
    New Port Richey Florida
    Have you tried teflon tape to seal the fitting or will teflone tape hold up to gas?? i dunno but its a thought. maybe the flare fitting is bad but still check both the o ring and the flare fitting
  2. #2 Re: Fuel rails
    GTP Level Member David99GTP's Avatar
    Florida
    Directions say teflon tape wont hold up to gas. I have gas resistant thread sealant, but that wont do me any good on a flare fitting. Looks like I may have to get an answer from PRJ at this point. I took my time and followed the 23 page instruction book closely.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  3. #3 Re: Fuel rails
    Florida
    Well, email sent to Paul at PRJ for advice. I wonder if my FPR is bad creating too much pressure on that side of the FPR. I drove out of the drive to turn the car around and it created a new leak at the quick connect. I am picking one up at NAPA tomorrow. I figure it cant hurt being the original with 110K on it. All my issues are on that side before the FPR.
    1999 GTP
  4. #4 Re: Fuel rails
    Wichita, KS
    On a flare fitting it can be damaged if its over tightened causing a leak, and if its under tightened, then obvious a leak too.
    They go together dry, and its not even a 1/4 when they mate to get them tight. If feels like its not even close to being tight, but it is.
    If it does leak, then its either a bad fitting, or the line going to the flare fitting is bad or damaged.
    You can use Teflon tape as a temp fix to see if that stops the leak, but i cannot say for sure if it will hold up to the fuel for long term use. I have used Teflon paste on my nitrous stuff, and it works well, but thats a totally different ball game.
    But on your fuel lines, the bigger one is the feed, and the smaller one is the return. Kinda impossible to hook them up backwards on a stock set of rails.
    There is a ground that bolts to the coil bracket. That handles the ground for the ICM (ignition control module).
    If it is a damaged part, I am more than sure the maker will take care of you, after all...you paid for the quality of the part, and should receive what you pay for.
    Holla if you need any help or more questions answered.
    ~F~
  5. #5 Re: Fuel rails
    Florida
    thanks!
    well i bought an new FPR. Thought it couldnt hurt being the old had 110K on it. Expensive little bugger. I then disconnected the whole right side. i ran the flex line in a different location than the directions suggested. this eliminated any lateral pressure on the fitting. After everything was connected I then bolted the box holding the FPR back on the bracket VS doing it in the opposite order as directions recomended. i had a new leak on the front right side of the rail. I was patient and tightened it a little, restart the car, tighten a little more, then restarted the car. After a few restarts no leaks. Reved the rpms and let the car run for a few minutes, no leaks. drove around the block, no leaks. Drove to the parts store, no leaks. It appears to be aok. Gosh I hope so! I didnt sleep much stressing over the issue. Paul from PRJ called to make sure I had it fixed. Sooooo Looks like I am in business. now into the paint shop and to the exhaust shop and hopefully ready for the show.
    1999 GTP
  1. Polishing stock fuel rails [*]
    By chitownchevy in forum How To Write-Ups/Tech Tips
    Last Post: 06-22-2009, 01:52 PM
  2. Update on my fuel rails
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2008, 11:07 PM
  3. PRJ Gen 3 fuel rails?
    Last Post: 02-10-2008, 02:42 PM
  4. Who's Done Homemade Fuel Rails (With an fittings)
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 04:13 PM
