Thread: Engine block
Results 1 to 6 of 6
  1. #1 Re: Engine block
    Nope...the only thing different is the pistons...the GT's are a higher compression...the rods and crank are the same.
    Since your top end is still good, remove it and clean it up good...might as well port your Supercharger while it is off too. If you do plan on high compression your going to be needing a tune and no WAY your going to be able to drop to a 3.5" or 3.4" with just a DP and other small bolt ons. 3.4" on a high compression build is nearly a 3.1" on a low comp. L67. Keep the stock pulley...you don't need a lot of boost to get power with a L36. If it is your DD then swap the L36 block in, port the S/C, get a 180*, Autolite 104's, 3" Downpipe, Custom CAI/FWI, and a tune...TUNE IS A MUST.
    Just putting it out there. Hope you get it done.
  2. #2 Re: Engine block
    SE Level Member slednut's Avatar
    Feb 2009
    Canada
    Well thats is easier for me to keep the stock pulley. Good to know. And it will be getting a tune. I know a guy around here that will do what ever i want and work with you untill you have what you like for $300. Thats were its going when i get it done. Thanks for the info.
    Ryan
  3. #3 Re: Engine block
    Feb 2009
    Canada
    So i found a block. Running 98 Monte Carlo with 249000 kms on it. Whole car for $300 bucks, so if anybody needs anything let me know.. I was wondering if it was worth it to put new bearings in the bottom end or to just leave them alone. And what about gasket brands, what to get or not to get. I was planning on getting the engine gasket kit from zzperformance.
  1. Engine block question for everyone
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2009, 10:14 PM
  2. ken block
    By blowfishRus6 in forum Off Topic Discussion
    Last Post: 06-04-2009, 04:19 PM
  3. same engine block?
    By JayGTP02 in forum Off Topic Discussion
    Last Post: 05-06-2009, 09:21 AM
  4. locations on 3800 Series engine block
    By ibduhone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2009, 12:33 PM
  5. New guy on the block
    By Milestone in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 12:17 AM
