Thread: Coolant elbow replacement walkthrough
Results 1 to 17 of 17
  1. #1 Coolant elbow replacement walkthrough
    SE Level Member Pogo D Klown's Avatar
    Sioux Falls
    okay seriously, I need to find a walk through on replacing the upper coolant return elbow, anyone know any website that will give me one. I 'm looking at it and to me it looks as thought I have to disassemble the entire upper pully system, pull off the alternator, and whatever lies beneath that. Is all of this necessary or do I just have to pop a cpl things off and pull out the elbow? STRESSED!! need to get it fixed asap!
  2. #2 Re: Coolant elbow replacement walkthrough
    Charles City, IA
    Take off the alternator and they are connected into the alternator bracket. You have to pull the alternator bracket off to. You might need to pull off one idler pulley. Its not hard. Replace both of them.
    SMGPFC Two Nipple General
  3. #3 Re: Coolant elbow replacement walkthrough
    Jan 2009
    Tallahassee, FL
    It's pretty straight forward. Go ahead and replace the second one and make sure that they didn't break off in the bracket or block. If they did they are pretty easy to remove.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #4 Re: Coolant elbow replacement walkthrough
    May 2008
    The '97 and '98 have only 1 plastic elbow. The other elbow is metal and part of the housing.
    Not sure about the '99. 2000 and up have 2 plastic elbows.
  5. #5 Re: Coolant elbow replacement walkthrough
    Year dependent issues:
    Move cooant bottle if it's on the strut tower
    97-98 wiggle alt tensioner bracket and don't pry as the lower elbow is metal and you could break the timing cover if you pry.
    Generic procedure:
    Drain 1/2 gallon of coolant
    Unhook negative cable of battery
    Untension accessory belt
    Remove the alternator to SC bolt (13mm)
    Remove the other alternator to tensioner bracket bolts and lay alt on top of SC.
    Remove alt tensioner bracket bolts and wiggle elbows out.
    Lube new elbows with oil or vasoline etc and put them in.
    Reassemble.
    The alternative procedure is to remove the LIM.
  6. #6 Re: Coolant elbow replacement walkthrough
    Oct 2012
    philly
    I have an 03 GTP. Can't get the coolant reservoir out to access the idler bolt. There is a bar that goes across the top of it and bolt to each strut tower. Does this have to come off? Looks like the nuts are inside the wheel well. is there a bolt at the bottom of the reservoir, or just the two at the top?
  7. #7 Re: Coolant elbow replacement walkthrough
    Apr 2011
    Elk Rapids, Michigan
    That's the strut tower brace. You'll have to remove it to get the coolant bottle out.
  8. #8 Re: Coolant elbow replacement walkthrough
    Yeah you dont need that bar that goes across the top send it to me ill make sure it gets disposed of properly.
  9. #9 Re: Coolant elbow replacement walkthrough
    Oct 2012
    philly
    I guess thats why they call you Slick??
    Bottle came right out once I unbolted the support bar. Was a breeze after that. So breezy that I bolted the support bar back before installing the bottle, lol.
    Still have a little drip from the bottle. Maybe 10 drops a minute?? I put a new clamp on the overflow hose. maybe there is a small crack inthe bottle?
    Anyway, my temp still doesn't get up to 190degrees. The temp gauge reads "160" - "l" -"210"- l- "260". I don't get past the first "l", I'm guessing 185?? Gonna replace the thermostat.
  10. #10 Re: Coolant elbow replacement walkthrough
    The stock gauge isnt accurate at all you're probably fine.
    GT Level Member Utter99's Avatar
    Warsaw indiana
    My stock gauge reads 160 with my aeroforce reading 130 then when my stock gauge reads right that first hash mark after 160 my aeroforce reads 175-180 if that help you out
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  12. #12 Re: Coolant elbow replacement walkthrough
    Oct 2012
    philly
    Thats what I figure, it's running about 175/180. I never paid much attention to the temp gauge till it got close to overheating one day. Turns out the radiator cap was not on properly. I got it back on tight and temp went back down. Not long after that the Service Engine Soon light came on. P0128 code, Low Coolant Temp.
  13. #13 Re: Coolant elbow replacement walkthrough
    Oct 2012
    philly
    Replaced the radiator cap. No change.
    Replaced the thermostat. Filled with coolant. Seems to be running at 195 now. I think the old thermostat was a 180. It has a stamp on it, A180
  14. #14 Re: Coolant elbow replacement walkthrough
    It was probably stuck open a 180* thermostat shouldn't throw a code.
  15. #15 Re: Coolant elbow replacement walkthrough
    Oct 2012
    philly
    Service Eng Soon light went out
  16. #16 Re: Coolant elbow replacement walkthrough
    Dec 2011
    chicago
    FYI, ZZP sells alumium elbow....
  17. #17 Re: Coolant elbow replacement walkthrough
    Oct 2012
    philly
    zzp?
    got it, thanks!
  1. anybody know where i can get a replacement.....?
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 08:46 AM
  2. 6x9 replacement
    By 99gpse in forum Audio, Security & Visual Electronics
    Last Post: 01-31-2009, 07:11 PM
  3. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
  4. Coolant Elbow Problem
    By Abrasive in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 08:39 AM
  5. Coolant Elbow Replacement on a 99-00 GTP?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 08:01 AM
