Thread: exhaust leak
Results 1 to 11 of 11
  1. #1 exhaust leak
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    ok i know i have an exhaust leak cause my whole car vibrates when i step on it. i just welded my cat back all up last night so i know its not that. so is the only way to check for a leak to put your hands around the exhaust?
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: exhaust leak
    Wausau, WI
    you could hold a piece of paper near it or something else soft that you could see the leak on. It should move the paper or whatever else you are holding that is soft next to the leak...
  3. #3 Re: exhaust leak
  4. #4 Re: exhaust leak
    Grayslake
    well what else could it be?
  5. #5 Re: exhaust leak
    i dont know, im not in your car. what does it feel like? what does it sound like? any codes?
  6. #6 Re: exhaust leak
    Grayslake
    well it just vibrates i cant really explain it. but ever since i put my new cat back on it been doing it
  7. #7 Re: exhaust leak
    Headers making contact with the floorboard? You do have Pacesetters
  8. #8 Re: exhaust leak
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Is it resonance or a vibration?
    Does your catback have a resonator?
    2006 Grand Prix GXP
  9. #9 Re: exhaust leak
    Donating Users blowfishRus6's Avatar
    g.a.
    maybe the catback is a little crocked. when i put my headers on my catback got pushed back alittle and the catback would hit the underside of the car.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  10. #10 Re: exhaust leak
    Grayslake
    i do have pacesetters i dont think its leaking from the it doesn't feel like it coming by my feet. yes i do have a resonator it the same one i had on my slp cat back.
  11. #11 Re: exhaust leak
    g.a.
    an exhaust leak wouldent vibrate. mine are still leaking some. the vibration would have to be something hitting somewhere. check over the whole system to make sure its not outta alignment or something.
    its slow.
  1. Exhaust leak, Whats the probable fix?
    By GPGT99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2009, 01:01 AM
  2. Need help with an exhaust leak
    By thenervemann in forum General Tech Discussion
    Last Post: 04-26-2009, 09:28 PM
  3. s/c leak
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 06:30 PM
  4. Oil leak exhaust headers
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2009, 08:33 AM
