Thread: 2003 gtp Exhaust ?
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 2003 gtp Exhaust ?
    SE Level Member brodyman's Avatar
    Jul 2008
    Colorado
    Ok.... Has anybody ever run with the exhaust disconnected just after the down pipe?? I'm talking at the track of course. I'm sure its loud as hell just curious if this will help e.t. at all!! Thanks.
  2. #2 Re: 2003 gtp Exhaust ?
    Jul 2008
    Colorado
    Oh yeah, My rear O2 is turned off.
  3. #3 Re: 2003 gtp Exhaust ?
    Wausau, WI
    it would not help.....IMO.....the stock cat back is rated for supporting 350WHP so it would not be of any gains other than the weight loss of the exhaust itself.
  4. #4 Re: 2003 gtp Exhaust ?
    A lot of people drop the catback at the track...your letting the car breathe more and getting rid of the weight from the catback...I'd do it if you don't mind bolting and unbolting the catback everytime you run it. And awesome...another '03
  5. #5 Re: 2003 gtp Exhaust ?
    Jan 1970
    Maquoketa, Iowa
    It probably wouldn't be worth it at all on a near stock car. Now if you had a cam'd/ic'd car setup for the track, then yeah, it wouldn't hurt. It still sounds like **** though.
  6. #6 Re: 2003 gtp Exhaust ?
    Jul 2008
    Colorado
    Yeah I'm not sure if I will. Its got a 3.4 pulley,cai,shift kit,ubend delete and a aftermarket torque convertor. I not to much into it sounding like hell any ways. I really need it tuned more than anything. Thanks for the replies!!!!
  7. #7 Re: 2003 gtp Exhaust ?
    You need more than a dropped catback and a tune to get away with a 3.4".
    I bet your knocking like crazy.
  8. #8 Re: 2003 gtp Exhaust ?
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Lets put it this way the Record 10 second 1/4 mile, Intense Racing, Turbo GTP runs with the cat back disconnected.
    This thing sounds like a jet.
    YouTube - 10 Sec Turbo Grand Prix GTP
    2006 Grand Prix GXP
  9. #9 Re: 2003 gtp Exhaust ?
    Wausau, WI
    Quote Originally Posted by DnaProdigy View Post
    that is also over 350 hp mark so obviously it would be restrictive at that point.....
  10. #10 Re: 2003 gtp Exhaust ?
    Jul 2008
    Colorado
    Thats funny! It has no knocks at all!!!!
  11. #11 Re: 2003 gtp Exhaust ?
    Wausau, WI
    Quote Originally Posted by brodyman View Post
    you scanned it and it has no knock at all?(KR)
  12. #12 Re: 2003 gtp Exhaust ?
    Jul 2008
    Colorado
    Quote Originally Posted by Liquifire View Post
    Yes sir! Although I wasn't at high speed when I scanned it. I tried to put it under a pretty good load in the amount of space I had. Should I go about it differently? Thanks.
  13. #13 Re: 2003 gtp Exhaust ?
    Wausau, WI
    you will have max knock at high rpms just before you shift usually....that is where your boost will be the highest, so that is where knock is the most prevelent
  14. #14 Re: 2003 gtp Exhaust ?
    Jul 2008
    Colorado
    Sweet thanks. I'll try that. Maybe I'll get someone to watch it while I drive!
  15. #15 Re: 2003 gtp Exhaust ?
    Wausau, WI
    I dont know how you couldnt have knock with no tune, no headers or plog/downpipe. You better check it again.......it almost has to. Most people knock some on stock everything or very light mods, let alone dropping the pulley size.
  16. #16 Re: 2003 gtp Exhaust ?
    Jul 2008
    Colorado
    I s**t you not! There is no knock!!!
  17. #17 Re: 2003 gtp Exhaust ?
    Wausau, WI
    no one would believe me that I had no knock on my stock setup.....you wont notice it until just before you shift or over 5 grand on the tach probably. How can your setup flow that good with no exhaust mods except the u bend delete? damn, and I was worrying about having some knock with DP and plog with a 3.4 on DHP's pcm.......maybe your sensors are broke.....LOL...what are using to scan with?
  18. #18 Re: 2003 gtp Exhaust ?
    Jul 2008
    Colorado
    Its a Snap-On scanner. I'm going to try it again just to make sure! Hell who knows? It runs pretty strong for being up at altitude. I'm thinking of putting a higher octane fuel in it for this weekend,what do you think?????
  19. #19 Re: 2003 gtp Exhaust ?
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    wow. if hes right on the whole no knock thing with the 3.4 then good on ya bro. like he said, almost everybody has knock with this setup. hell most people have at least a couple degrees even after a complete 3.4 setup and have to get it tuned out.
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  20. #20 Re: 2003 gtp Exhaust ?
    Get a scan at the top of second gear...like around 70-90...that is where most KR is. If you have access to a tuner...aka DHP Powertuner or HP Tuners software that will give you a REAL scan and tell you what is really going on. I had KR with a 3.5" pulley with a ported front manifold, 3" DP, U-Bend Delete, 3" Catback, 180*, AL104's, DHP PCM, 1.84:1 Roller Rockers and a FWI. About 2-3* up top of 2nd.
  1. 2003 GTP BIN. Does anyone have one?
    By GeddyLee in forum PCM Tuning
    Last Post: 09-09-2010, 11:40 AM
  2. 2003 misfire
    By swarley in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-06-2009, 09:22 AM
  3. 2003 GT vs 2003 mitsubishi eclipse GTS
    By kjohnson in forum Track Sessions and Kills
    Last Post: 04-01-2009, 11:27 AM
