Thread: Question for the meth-heads
Results 1 to 20 of 26
  1. #1 Question for the meth-heads
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Those running meth/water/alky injection, how do you know that it is working? I would have thought that scanning would show the engine going uber-rich at WOT, but it really did not seem any different. It seems like I am topping out at 11-12psi, and I have the controller maxing out at 10psi, how does that sound?
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  2. #2 Re: Question for the meth-heads
    Banned - Busted For Scamming
    Feb 2009
    What size nozzle are you running?
  3. #3 Re: Question for the meth-heads
    Waynesboro, PA
    M5 through a TB spacer.
  4. #4 Re: Question for the meth-heads
    I know this sounds dumb...and possibly not worth it Josh...but can't you unhook it and run it with the current tune and scan for KR...then if you get any re install it and scan again...I know it sounds pretty noobish but just one of those things I would never think about because it seemed to basic.
  5. #5 Re: Question for the meth-heads
    Waynesboro, PA
    I definitely can, but am wondering what I should see.
  6. #6 Re: Question for the meth-heads
    the only way i knew mine was running is because i ran SLIGHTLY richer as well as my boost level going up SLIGHTLY and my knock being literally zero no matter what i did.
  7. #7 Re: Question for the meth-heads
    Waynesboro, PA
    That might be all there is to it, then. I still have a touch of knock, but I have not done much updating to the tune so I am sure I can get rid of it.
  8. #8 Re: Question for the meth-heads
    i usually had it start spraying around 6-7 psi and 100% at like 10-11 psi. what are you running for your meth percentage? 50/50?
  9. #9 Re: Question for the meth-heads
    Bastard Reptile's Avatar
    Kansas City, MO
    It really has to do with what mixture you run vs. what nozzle. I think when I first got my setup, and the DO5 nozzle w/ washer fluid, I saw my AFR drop almost 1.5 into the low 10's. Now on the DO10 and 100% I see about the same, but only because more of the meth is getting burned up in the cylinder since there's not any water in it. The washer fluid quenches the flame a bit, so it really does it's job as a kr killer. I'm using mine as strictly a fuel additive now, and it seems to work pretty well for me.
  10. #10 Re: Question for the meth-heads
    thats what i was going for too. i wanted as much octane as i could get. an e85, meth, rockered setup didnt get me 12s then i didnt know what else to do (besides go bigger).
  11. #11 Re: Question for the meth-heads
    Kansas City, MO
    Wait till you see what I have in store for the car over the downtime season.
  12. #12 Re: Question for the meth-heads
  13. #13 Re: Question for the meth-heads
    Kansas City, MO
    Kinda.....cam...HEADS, and a compression bump will be teh shiznit.
  14. #14 Re: Question for the meth-heads
    Donating Users blowfishRus6's Avatar
    g.a.
    i remember he bought an intense stage 4 cam a while back if that clues us into anything...
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  15. #15 Re: Question for the meth-heads
    Quote Originally Posted by blowfishRus6 View Post
    Who Brian?
    No...no stage 4...something custom
  16. #16 Re: Question for the meth-heads
    g.a.
    doh
    its slow.
  17. #17 Re: Question for the meth-heads
    Kansas City, MO
    Who Brian?
  18. #18 Re: Question for the meth-heads
    Waynesboro, PA
    I have been tuning without it, but I am pretty sure I will see more in the scan next time I turn it up. I tossed a check-valve in-line near the nozzle that came with the kit when I bought it off of another forum member. I am almost certain it was a huge restriction, so I have removed it. We will see what kind of difference it makes over the next few days.
  19. #19 Re: Question for the meth-heads
    i never had a problem with that check valve. did you put it in the right way?
  20. #20 Re: Question for the meth-heads
    Waynesboro, PA
    Which check-valve? The black plastic one, or the metal one? They were both installed the proper direction, and there was flow, but the black one is a huge restriction compared to the metal one.
  1. Meth vs Intercooler
    By Risinnfallen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 02:04 AM
  2. meth inj/ ic
    By blk03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 07:17 PM
  3. Well I done did it guys.(Meth Injection)
    By ChrisJ in forum General Tech Discussion
    Last Post: 04-19-2009, 10:58 AM
  4. Question about L26 heads
    By Quicklynx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-06-2008, 03:13 PM
