The map sensor is on the firewall in the center. It may be tied to a bracket. Its a black box with a L-boot and a vac line and a electrical connector. Follow the vac line under the Supercharger snout T-Fitting. The back line will lead right to the map sensor.
Check all lines to make sure they are connected and not cracked.
Hope this helps!
