Thread: Engine Swap?? 2006 to 2004
Results 1 to 15 of 15
  1. #1 Engine Swap?? 2006 to 2004
    so mo
    Hi all my wife wrecked her 2004 grand prix and I found a 2006 grand prix gtp and was wondering if all the parts were interchangeable and if its possible to swap the other gtp motor into her 2004 car? I heard about maybe reprogramming the pcm? thanks.
  2. #2 Re: Engine Swap?? 2006 to 2004
    Aug 2008
    KCMO
    no you have to take the wiring harness and the pcm from the 06 and put it in the 04 i believe
  3. #3 Re: Engine Swap?? 2006 to 2004
    Wausau, WI
    your gas gauge might read backwards(not sure) due to the different PCM's
  4. #4 Re: Engine Swap?? 2006 to 2004
    Also...you might run into a few issues if you had a '04 Comp G vs. a GTP.
  5. #5 Re: Engine Swap?? 2006 to 2004
    so mo
    Hers was a gt. but other than motor doesnt all the body parts interchange? thanks for the replys! would i have to reprogram the pcm or just use all the brains and wires from the 06?
  6. #6 Re: Engine Swap?? 2006 to 2004
    SE Level Member reallyfast1's Avatar
    Aug 2008
    CAMBRIDGE,ONTARIO,CANADA
    in 2006 the GTP was just a GT but still S/C!! and if she wrecked the 04 why bother rippin apart the 06??
  7. #7 Re: Engine Swap?? 2006 to 2004
    so mo
    ya I was thinking about that, the only thing is Im not sure how bad the 06 is compared to the 04 and if the 06 has a title or if its salvaged.
  8. #8 Re: Engine Swap?? 2006 to 2004
    Aug 2008
    KCMO
    Quote Originally Posted by gmangrandprix View Post
    well the 06 for one is S/C and has a little better trim in the interior and is actually black and not charcaol like the 04 (if they are both leather) and if it has a good title and the car is clean then take it to a mechanic and have them look it over and then just drive it. and does the 06 have a less miles then your wifes 04?
  9. #9 Re: Engine Swap?? 2006 to 2004
    so mo
    Well He said it only has 75k miles and my wifes has over 100k. the only prob is he used the tranny out of it, would my wifes gt tranny hold up to the other gtp. Im waiting for the pics of it but it sounds like it has nicer interior and features for sure. so I may just fix up the 06. its a coffe color he said.
  10. #10 Re: Engine Swap?? 2006 to 2004
    Aug 2008
    KCMO
    no your wifes tranny wont hold up you well need the tranyy that goes with the supercharged motor.
  11. #11 Re: Engine Swap?? 2006 to 2004
    so mo
    Well would it hook up to it and work at least? I could take it easy as money is very tight and cant really afford different tranny.
  12. #12 Re: Engine Swap?? 2006 to 2004
    Aug 2008
    KCMO
    im not sure
  13. #13 Re: Engine Swap?? 2006 to 2004
    It should...just wouldn't be a good idea IMO. The L26 and L32 are essentially the same motor...
  14. #14 Re: Engine Swap?? 2006 to 2004
    Wausau, WI
    it will work and may last a while depending on your driving habits and how much you like the SC.......
  15. #15 Re: Engine Swap?? 2006 to 2004
    so mo
    lol ya itd be hard not to get in it with more power like that. but she would mainly be driving and she isnt a hot rod thankfully.
  1. Engine Swap
    By swapthe98 in forum Engine
    Last Post: 09-26-2009, 11:41 PM
  2. Engine Swap
    By swapthe98 in forum How To Write-Ups/Tech Tips
    Last Post: 07-24-2009, 09:00 AM
  3. Engine swap?
    By Spacedonut in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-24-2009, 02:01 PM
  4. Engine Swap
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 04-04-2009, 09:56 AM
  5. Engine swap
    By BankRupt in forum Off Topic Discussion
    Last Post: 07-19-2008, 11:06 AM
