I have a 97 GTP
Not To Sure How To Get It Out
Anybody Help Me I Need To Wash It Out
I have a 97 GTP
The easiest way for me was to remove the angled bar that goes from your front radiator support to the side near the drivers side fender. Then I removed my stock air box by disconnecting the intake tube from it. Then open up your air box and remove the filter and disconnect the three( I think it is three) bolts on the bottom of the airbox under the PCM. You may take the PCM out of the airbox if the airbox is still in your way while trying to remove the overflow coolant bottle. Once that is out of the way, I think there is only one bolt holding in the coolant overflow on the drivers side bottom. There may be one more plastic mount piece for the bottle, but I cant remember for sure........it is a lot easier than I am making it sound. If you can get to that one bolt at the base of the radiator coolant bottle without removing the airbox( I removed both of mine at the same time so I dont remember for sure) it should only take aobut five minutes...good luck
