Thread: oxygen sensor
Results 1 to 6 of 6
  1. #1 oxygen sensor
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    i was told that the front and rear o2 sensor are the same one. is that true?
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: oxygen sensor
    Apr 2009
    stockton ca
    Rock auto lists 2 differnt parts codes for direct fit replacments in each brand so im going with there not the same
  3. #3 Re: oxygen sensor
    Wausau, WI
    call gm............see if they have 2 different part numbers.
  4. #4 Re: oxygen sensor
    they are COMPLETELY different. the rear one is only there to monitor the post-cat emissions and does nothing to help tune the car. the front one is what the car needs to run.
  5. #5 Re: oxygen sensor
    Charles City, IA
    ^ yup
    SMGPFC Two Nipple General
  6. #6 Re: oxygen sensor
    Grayslake
    alright. i was hoping i didn't have to spend more money.
    thanks everyone.
  1. bad map sensor?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2022, 06:58 AM
  2. No o2 sensor ??
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-07-2009, 05:55 PM
  3. Is it possible to run without an O2 sensor?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 06-19-2008, 11:45 AM
  4. L67 MAF Sensor
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 06:00 PM
  5. Falling mileage w/ new oxygen sensor.
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-23-2008, 07:48 AM
