Thread: Which Modular Pulley System is the best?
Results 1 to 17 of 17
  1. #1 Which Modular Pulley System is the best?
    Wausau, WI
    Well........I will be looking to get an MPS setup after I have all of the supporting mods. I will not be going beyond the 3.4 setup and I just wanted to know what MPS system to go with. Are there any poor quality setups to avoid? What I am really looking for is the best "quality value" meaning the best quality setup for the lowest price. I am looking for suggestions so please advise away........Thanks guys and gals....Please share any positive and negative experiences that you have had.
  2. #2 Re: Which Modular Pulley System is the best?
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    I'm pretty sure most people will recommend ZZP for both price and performance.
    2006 Grand Prix GXP
  3. #3 Re: Which Modular Pulley System is the best?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    I have always recommended D.U.B systems via south Florida pulley Hq
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: Which Modular Pulley System is the best?
    ZZP/intense because they are the easiest to find used which makes getting smaller pullies later on super easy.
  5. #5 Re: Which Modular Pulley System is the best?
    Wausau, WI
    yeah.........steel or aluminum......the DUB system doesnt even offer a 3.5......ZZP is steel.........DUB is aluminum. Also, who has the best pricing on pulley pullers for rental or for purchase.
  6. #6 Re: Which Modular Pulley System is the best?
    Wausau, WI
    good thing to consider........
  7. #7 Re: Which Modular Pulley System is the best?
    don't be cheap. and forget about a press on pulley
  8. #8 Re: Which Modular Pulley System is the best?
    Wausau, WI
    I am not being cheap.......I just don't want to overpay for something. Like I said in the first post. I want good quality at the best price.....obviously I am not going with a press on pulley if I asked for advice on the MPS set up.....
  9. #9 Re: Which Modular Pulley System is the best?
    ZZP MPS.
    That is all.
  10. #10 Re: Which Modular Pulley System is the best?
    Jan 1970
    Maquoketa, Iowa
    ZZP/Intense are basically the same MPS.
    You could also get pulleys from nate herbst from Minnesota. He can make any size pulley you want and for any hub you may have. They are quality pulleys and hubs, using allen screws that sit flush with the pully when installed. Stainless steel hub/screws and aluminum pulleys that are a lot lighter than zzps'.
    Contact him here for price- nherbst396@yahoo.com
  11. #11 Re: Which Modular Pulley System is the best?
    Quote Originally Posted by FoSHO99 View Post
    Really? That's pretty cool and he does it for the general public or do we have to go through you since you know him...?
    Great info nonetheless...do you think he is cheaper than ZZP/Intense?
  12. #12 Re: Which Modular Pulley System is the best?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The main differences are fairly small. The ZZP and Intense pulleys are 8 ribbed, so you can use them with either a 6 or 8 ribbed setup. On the other side, the Smoothflow/WBodyStore/PulleyBoys are 6 ribbed and lighter. They're also not as popular, but they do come up for sale pretty regularly.
    The other systems, Thrasher, DUB, etc are usually more limited in pulley selection, as well as not being as popular so used pulleys aren't as easily available.
    Nate does sell to the general public, his site is Smoothflow Pulleys
    2001 Buick Regal LS - Almost Stock
  13. #13 Re: Which Modular Pulley System is the best?
  14. #14 Re: Which Modular Pulley System is the best?
    Wausau, WI
    Looks like ZZP or Nate at this point.........anyone have any horror stories or bad experiences with either of them?
  15. #15 Re: Which Modular Pulley System is the best?
    i have metal idlers from nate. they rule.
    Metal Idlers?
    Send me a PM about this bish
  16. #16 Re: Which Modular Pulley System is the best?
    ill take some pictures when i get a chance and post them up. sending you a PM right now though.
  17. #17 Re: Which Modular Pulley System is the best?
    You-a so nice-a...
    Those are pretty trick though. If I had $160 to blow right now I'd be on top of that shiz
  1. Modular Vs. Press On Pulley
    By Bigbm80 in forum General Tech Discussion
    Last Post: 06-12-2009, 09:58 AM
