Thread: vacuum pressure
Results 21 to 40 of 42
  1. #21 Re: vacuum pressure
    Wausau, WI
    personally I would try and re seal the EGR that you have blocked off, but I am not sure what else to tell you.......you use the 6 cent method of sealing off the egr?
  2. #22 Re: vacuum pressure
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    Quote Originally Posted by Liquifire View Post
    i used a penny and copper rtv to seal it.
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  3. #23 Re: vacuum pressure
    Wausau, WI
    I would just pull it out of the egr clean it up, and re seal it if you can. Or at the very minimum go over it again and put a full layer over the top of what you have already. If it wasnt cured all the way when you started it up, you could possibly have broken the seal on this??? IDK.....
  4. #24 Re: vacuum pressure
    Wausau, WI
    sorry.......wish you the best of luck.....keep us posted.
  5. #25 Re: vacuum pressure
    Grayslake
    well ill try that tomorrow. i really hope this is whats wrong with it.
  6. #26 Re: vacuum pressure
    Wausau, WI
    personally I would try the carb cleaner trick to locate it first if you can. spray liberally in any vacuum areas starting with the EGR location......
  7. #27 Re: vacuum pressure
    TDCRacing
    Guest
    Yeah keep us posted man. We will help you the best we can.
  8. #28 Re: vacuum pressure
    Grayslake
    alright i got to buy some card cleaner now i used it all on my snowmobile last winter that pos. so i can just spray it in the lines and it will be fine?
  9. #29 Re: vacuum pressure
    TDCRacing
    Guest
    Yep.
  10. #30 Re: vacuum pressure
    Grayslake
    alright. ill let you know what happens tomorrow then. thanks for all of your guys help
  11. #31 Re: vacuum pressure
    Wausau, WI
    Quote Originally Posted by grand2000prixgtp View Post
    it will not hurt anything.......if anything you might clean something in there by accident.......LOL.......it is designed to go in there, so dont worry about it harming anything.
  12. #32 Re: vacuum pressure
    Grayslake
    how much should i spray in there
  13. #33 Re: vacuum pressure
    TDCRacing
    Guest
    Just spray a cupple squirts along oll of the vacuum areas. If there is a leak you should hear the engine idle higher when you hit the vacuum leak.
  14. #34 Re: vacuum pressure
    Grayslake
    Quote Originally Posted by TDCRacing View Post
    alright thanks
  15. #35 Re: vacuum pressure
    TDCRacing
    Guest
    No problem man
  16. #36 Re: vacuum pressure
    Grayslake
    well good news got the car running it was the egr leaking.
  17. #37 Re: vacuum pressure
    TDCRacing
    Guest
    Awesome!
  18. #38 Re: vacuum pressure
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Ok now that that's solved help me! ha.
    My vac is only -12 at idle. While driving a low speeds its around -9. When i hit the gas with my stock pulley it was 6.
    I changed the pulley today (3.5") the only thing that changed is boost is at 8 under WOT.
    Since the boost is where it should be could i assume the gauge is working correctly and my vac is less then it should be?
    What i have checked...
    All vac lines (boost gauge, t-fitting below MAP, t-fitting below snout, T-fitting to the fuel pressure reg, and connection to the thing in front of the bypass valve [if someone knows the name fill me in])
    What should i check next?
    2006 Grand Prix GXP
  19. #39 Re: vacuum pressure
    Wausau, WI
    so you want lower vac at idle or what? I know max boost is not a good thing to go by because that only tells you how much resistance that you have getting the air out of your pump(motor/exhaust) so 8 pounds just means you are getting it out well. You may have a vacuum leak and if so check as stated above. Has it been this way for a long time? do you have a way to scan for it at all times? have you changed any parts recently or done any work which may have effected this? Checked brake booster?
  20. #40 Re: vacuum pressure
    Wausau, WI
    glad to hear it........now you dont have to threaten to take off the headers anymore...........how does the car run now with headers compared to before them?
  1. vacuum pressure problem
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 11:47 AM
  2. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  3. Vacuum hose
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2008, 07:01 AM
  4. car has vacuum in the dipstick
    By lilredss0287 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2008, 06:44 PM
  5. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
