Thread: Front mount intetcooler
Page 13 of 18 FirstFirst ... 31112131415 ... LastLast
Results 241 to 260 of 351
  1. #241 Re: Front mount intetcooler
    GTP Level Member Scimmia's Avatar
    QCA, IA
    If the stock PCV inlet is blocked, breather = unmetered air = rough idling. Not hard to figure out.
    2001 Buick Regal LS - Almost Stock
  2. #242 Re: Front mount intetcooler
    usa
    Quote Originally Posted by Davisgtp View Post
    Any body got a front mount intercooler on there car I'm thinking about getting one
    Hello
    I got one last month from www.autopartsway.ca.
  3. #243 Re: Front mount intetcooler
    Banned - Busted For Scamming
    Feb 2009
    the design is fine
  4. #244 Re: Front mount intetcooler
    Quote Originally Posted by silverstreak View Post
    Were any of these ever tested on your own car Mini or did you just make them and send them out and hope for the best?
    Nope...never tested. That is the deal. I'd never buy something that wasn't thoroughly tested.
    Quote Originally Posted by PETCAR View Post
    Hello
    For what...a Honda?
    the design is fine
    Apparently not if the car is running like crap with it.
  5. #245 Re: Front mount intetcooler
    Feb 2009
    The pcv function was known about and could be fixed, therefore there is nothing wrong with the core. Im still willing to bet that there is a vacuum leak somewhere that didnt get taken care of. I would try the silicone gaskets before he condemns it.
    Colin- if you need some silicone gaskets let me know ill send some for you no charge.
  6. #246 Re: Front mount intetcooler
    Feb 2009
    Actually, i may have not tested the phenolic version, but i did have the very first intercooler i made, aluminum version, on my car for a little while and it ran fine. I used an oil/air separator from a 2.3 quad 4, which is the same thing as an oil catch can. I took it off to make a phenolic version and never had the time to make one for myself unfortunately, but i have no doubt they work with no problems.
  7. #247 Re: Front mount intetcooler
    in a house
    He's installed this thing 3X, do you really think he wants to mess with it anymore? He's already said he wants to sell it, why dont you buy it off him, install it on your car and prove that its not a design issue.
  8. #248 Re: Front mount intetcooler
    QCA, IA
    I swear, this forum is a bunch of rabid dogs, almost as bad as ClubGP.
    Mini's right, there was a vac leak. THE BREATHER.
    I'm certainly not saying this was handled correctly, but come on guys, stick to what's really the problem here.
  9. #249 Re: Front mount intetcooler
    Feb 2009
    Scimmia, i guess im not following you here on this, both sides of the pcv are blocked on the core, would that make a vacuum leak and where?
  10. #250 Re: Front mount intetcooler
    QCA, IA
    If both sides were blocked, it wouldn't matter. In the other thread, though, he took off the breather and said he was feeling vacuum at the front valve cover, which means the crankcase is connected to vacuum somewhere.
  11. #251 Re: Front mount intetcooler
    Feb 2009
    Hmm, yea that is weird. Both sides definitely are blocked on the core though, and he said he used lots of sealer on it the second time. I have no idea what could be the matter, but im pretty sure its not the i/c core.
  12. #252 Re: Front mount intetcooler
    QCA, IA
    In that case, there's probably a leak between the intake and crankcase elsewhere. With the stock PCV system functional, it would be pulling metered air, so it really wouldn't matter, but with it blocked and a breather, it would cause problems. The question is where? LIM? Heads? It could potentially be where the IC meets the LIM, but if he used that much sealant, I don't know how.
  13. #253 Re: Front mount intetcooler
    Feb 2009
    Well i dont know either, he said he pulled the intercooler off and put the supercharger back on and it runs fine...
  14. #254 Re: Front mount intetcooler
    QCA, IA
    Yep, very possible. With the stock inlet functional, a leak between the crankcase and intake would act as a slightly stuck PCV valve, the air is already metered and accounted for, so the IAC takes care of keeping the engine at the right RPM. With the inlet blocked and the breather on, it would be a vacuum leak.
    With both the inlet and outlet blocked, you should have positive pressure on the front valve cover, not negative. For the IC to be at fault here, it would have to be a serious design defect, such as the core extending all the way into one of the PCV passages.
  15. #255 Re: Front mount intetcooler
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    Quote Originally Posted by bbptech View Post
    Hey Douglas, ZZP actually has gotten better at answering there phones. They arent busy all the time anymore. And they even returned my call. They musta finally realized how ****ty there customer service was.
    or they just realized no one can buy there stuff if they dont answer their phones.
  16. #256 Re: Front mount intetcooler
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Ive had this thing on and off more than enough times. Im done screwing with it. I know i had enough silicone on it ensuring there wasnt a vacuum leak. Tested it everytime with carb cleaner to second that there wasnt a leak. Like i said i didnt even use a new S/C gasket the last time when just putting the S/C back on and no intercooler and everything is running fine. Not going to mess that up. Havent been able to drive the car for over a month and a half so now that i am able to drive it now, dont wanna be taking everything off again. I know im not gonna get a refund for this so just gonna sell it. Next time i know i wont be buying something that hasnt been fully tested. Live and learn.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  17. #257 Re: Front mount intetcooler
    Lol and ya that too. At least they realized and are fixing there ****
  18. #258 Re: Front mount intetcooler
    Apr 2009
    ERIE
    send these with mine then
  19. #259 Re: Front mount intetcooler
    Apr 2009
    ERIE
    i have a lim and extra supercharger....at least when i get mine i can play withit off the car and find the flaw if there is one. logan....you better promise me if i find something wrong your gonna fix it. like i said earlier..i expect you to come out with multiple versions of your product as nothing ever works right the first time...im cool with that as long as my input means a fixed intercooler or a new one with corrected design. im not gonna lose faith now if you promise to work with me.
  20. #260 Re: Front mount intetcooler
    u know i just went out to the shop right after i replied the last time. this ****in core doesnt sit flush. i sat it on the table and it dont sit flat at all. u know what i want a ****in refund this is bull****.
  1. 2004 GTP Front License Plate Mount
    By ILjXYZ in forum Visual/Body Modifications
    Last Post: 06-16-2009, 12:13 PM
  2. Where should I mount my amp?
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2009, 06:35 PM
  3. Front Strut Mount from Advance Auto Parts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 04-02-2009, 11:53 AM
  4. 98 NAPA Front Strut Tower Mount
    By Lion29GTP in forum Brakes/Suspension/Chassis
    Last Post: 03-10-2009, 02:10 AM
  5. Front Motor Mount Brackets..
    By GP2003GT in forum Visual/Body Modifications
    Last Post: 03-31-2008, 11:31 AM
