Thread: blown 3800 swap into a 1995
Results 1 to 13 of 13
  1. #1 blown 3800 swap into a 1995
    SE Level Member mikefeelsgood's Avatar
    madeira, ohio
    I have a '95 GP and want to swap in a supercharged 3800 with a 5 speed. Is there anyone who has done this? what kind of modifications need to be done to bolt the buick engine in place of my chevy 3.1?
  2. #2 Re: blown 3800 swap into a 1995
    5 speed? good luck. youll break any transmission you put behind our motor.
    otherwise the engine is pretty well a drop and play so long as you have the wiring harness adapters and pcm. you also need different length axles.
  3. #3 Re: blown 3800 swap into a 1995
    Banned - Busted For Scamming
    Feb 2009
    Lies. Its been done before successfully. The twincharged cutlass had the getrag 282 its a damn strong tranny. I planned on going with the 5 speed conversion when i get the time and money.
  4. #4 Re: blown 3800 swap into a 1995
    madeira, ohio
    Yea last time I checked(and I could be mistaken)the getrag 282 was tested up to 600hp on all stock parts and was STILL holding up. I've seen fieros with LT1's and the 5speed before. So will the 3800 and 282 both just drop in?(Besides the usual auto to manual parts swap deal) That sounds too good to be true.
  5. #5 Re: blown 3800 swap into a 1995
    pretty sure you need to figure out a way to mate the trans with the engine. i could be mistaken and they might bolt right up though..
  6. #6 Re: blown 3800 swap into a 1995
    madeira, ohio
    Yea, but I see so many fieros with the 3800/282 setup that I figure it can't be too hard. And I read about gm making a test bonneville with the blown 3800 and the 5 speed and it was insane. I just need advice on what axles to use and all that. Also, if there's anyone who can give me a round about number of what getting the blower ported would cost, I'd appreciate it. I'm only planning moderate building to the engine. Smaller pulley for sure on the blower, and maybe a cam. I'm hoping to find some good headers for it too. But this is a daily driver for me so I don't want to take away from too much driveability comfort
  7. #7 Re: blown 3800 swap into a 1995
    madeira, ohio
  8. #8 Re: blown 3800 swap into a 1995
    Feb 2009
    Check this guy out, will give you some ideas.
    http://www.cardomain.com/ride/2458244/2
  9. #9 Re: blown 3800 swap into a 1995
    Tofu Delivery Boy Lsick7's Avatar
    MO
    That cutlass is straight up innovation, it...is....SICK!!!! MP112 and turbo'd, good lord.
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  10. #10 Re: blown 3800 swap into a 1995
    Feb 2009
    Thats a whipple.
  11. #11 Re: blown 3800 swap into a 1995
    Thats a whipple.
    Actually...it is a Cobra MP112 supercharger with the custom nose drive for the 3800 platform. Whipple's have branded their name plate in the side of their blowers.
    Plus...it says it on his Car Domain.
  12. #12 Re: blown 3800 swap into a 1995
    madeira, ohio
    That's a pretty cool setup on that olds. I like the suspension mods the most. I want to upgrade the handling as much as reasonably possible. But that's for another thread, isn't it? Haha.
  13. #13 Re: blown 3800 swap into a 1995
    madeira, ohio
    if theres anyone with the info on how to get the 282 and L67 bolted up and running together, and anything on whatevers needed to bolt the setup in place, please let me know. so far, i think i have to use an f body flywheel with .24" machined off
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. 3800 SC III swap... What do I need to salvage?
    By Rolling Thunder in forum General Tech Discussion
    Last Post: 01-24-2017, 10:01 AM
  3. 1995 GTP engine swap to a SC3800
    By ArcticWhiteGTP in forum General Tech Discussion
    Last Post: 06-21-2009, 11:24 PM
  4. 3100 to 3800 swap questions
    By MRJ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-01-2009, 09:52 AM
  5. Latest S2 3800 Swap FINISHED!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 07-24-2008, 02:16 AM
