Thread: pulley swap question
Results 1 to 15 of 15
  1. #1 Re: pulley swap question
    SE Level Member Robotech's Avatar
    California
    Definately go with a DHP PCM if you can get one. For the level of modding you're wanting to do they are perfect and well tested by the community.
    Front manifold is very easy to get off IF you have the proper tools. I believe they are 1/2" (13mm) in size. Be sure to have a open end wrench and a good fitting socket to get to them. I'd also be sure to have some extensions and a swivel as these will make removing them even easier. As was mentioned above...a little PB Blaster will make your life easier too.
  2. #2 Re: pulley swap question
    SE Level Member jersey jok3r's Avatar
    Northern New Jersey
    I appreciate all your help guys
  1. Supercharger Pulley Swap [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 12-04-2011, 03:16 AM
  2. Pulley swap question ------>>> NEW GUY
    By mjm06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 01:00 AM
  3. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  4. another top swap question
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2009, 12:59 PM
