Thread: clear codes
Results 1 to 20 of 22
  1. #1 Re: clear codes
    SE Level Member Incomudrox's Avatar
    New Holland, PA
    Or...you can pull the PCM fuse and put it back. But to answer your question 30min.
  2. #2 Re: clear codes
    St. Louis Mo.
    If you had my LS1m Toasty, you could clear that way
    LOL sorry brother, it was to easy to pass up
    I agree with the above, 30 minutes to an hour is what I have done before to clear codes. Just be aware of what the code might be, you dont wanna go blowing anything up ya know
    James Shafer
    St. Louis MO
  3. #3 Re: clear codes
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Can all codes be cleared by disconnecting the battery?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: clear codes
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by GeddyLee View Post
    hahahaha yer sooo funny
    my LS1m parts are on the way. should be a fun assembly project
    perhaps i even will save $$ vs what you paid :P
  5. #5 Re: clear codes
    St. Louis Mo.
    Quote Originally Posted by Toasty View Post
    You know I had to poke a little jab in there my friend
    Good luck on the project. If you have any questions or need to take any photos of mine for ya? Please let me know. I will be more than glad to help ya with as best I can.
    James Shafer
    St. Louis MO
  6. #6 Re: clear codes
    SW Chicago Suburbs
    I had that same code before. It read that bank 1 sensor was the problem. IE an O2 Sensor. At least that is what the Autozone computer said. I thought maybe I hit the rear sensor at the top of the DP when I was changing out factory spark plug wires.
    So I went back in and disconnected the battery the following the morning and left it offline for almost 2 hours and came back and rechecked all connections, even the O2 Sensor and then reconnected the Power to the battery and the code was cleared. Hadnt come back since.
    Glitch or not? Not sure cause if it was truly a bad sensor it would have kept coming back.
    the P0171 is NOT an O2 code. i know it seems like it could be, but it's not, at least according to the trouble code diagnostics from GM that i posted up over on the how-to section. anywhoo, mine was a vac leak, allowing unmetered air into the system after the MAF.
    Thanks for the help... Mark is gonna assemble most of it i think, i may need to sacrifice a usb cable to put it together, but that should be about it.
    but if i get stuck, i'll give ya a holler.
  1. OBDII Codes [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-26-2011, 01:23 AM
  2. Paint Codes
    By thermanlee in forum Visual/Body Modifications
    Last Post: 01-14-2008, 11:39 PM
  3. OBD2 codes
    By sra_chipmunk in forum Forum Bugs/Suggestions
    Last Post: 01-14-2008, 12:56 AM
