Thread: Oil Leak
Results 1 to 5 of 5
  1. #1 Re: Oil Leak
    a) why are you running colder plugs without running more boost? youre supposed to run as hot of plugs as you can. stick with the stock heat range.
    X2...
    b) the pan gasket might be leaking. they tend to do that after a while.
    And...have fun with that if it is. They are a b*tch and a half to do with the motor and everything in the car IMO.
  2. #2 Re: Oil Leak
    SE Level Member streetsmart's Avatar
    Apr 2008
    Red Lion, PA
    I was thinking it was the oil pan. Looks like I won't be trying that one myself. I appreciate the feedback!
    I know what you are saying with the plugs but these actually worked better than stock plugs. Besides, the 3.4, 180 t-stat, CAI and headers will be on soon (as soon as it becomes a 2ndary vehicle in about 3k miles.)
    01 GT Black 2 DR
    98 GTP Black 4 DR
    04 Comp G Black 4 DR
    I just can't seem to get my fix!
  3. #3 Re: Oil Leak
    Apr 2008
    Red Lion, PA
    Yeppers, its the oil pan. Not only that but it suddenly started leaking power steering fluid and coolant. Not sure why this happened at once but I will be getting rid of this car. Only 74K miles and already these problems......yikes.
    01 GT Black 2 DR
    98 GTP Black 4 DR
  1. antifreeze leak..
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:36 PM
  2. s/c leak
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 06:30 PM
  3. oil leak
    By whitegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 03:48 AM
  4. Pin Piont The Leak ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 08-25-2008, 07:16 AM
  5. Oil leak
    By fiveinthelive in forum General Tech Discussion
    Last Post: 03-11-2008, 09:35 AM
