if you make sure the crank gear and everything are good and the set sits right then who cares? no one ever said it was a completely plug and play part. the problem is that some were machined with slightly different tolerances and the crank gear MIGHT sit out a little too far running the chain at an angle and wearing it prematurely. i did none of this and am running with a machined oil pump cover and so far so good.
