true..any other downsides? and r there any upsides? ill so do this tomorrow if u can give some info as these things suck. can i use hp tuners to remove the codes?
i havent had a egr for awhile now and there are no downsides at all my MPG's are the same....the upsides are cleaner air going in and less carbon build up in the TB and more room in the engine bay...and yes you can rid the codes with hptuners....i've deleted the cat, egr, and EVAP system from my car....3 things less to worry and better sounding exhaust...
Info? They suck Period
Take off your intake tube and see all that black crap/gunk built up in your throttle body...all of that is from your EGR...clean your TB and get rid of the EGR. All you need is 2 pennies and RTV...cut the stock brackets off of the EGR Tube on each end that would bolt to the header/manifold & the LIM. Then put a penny in each larger hole and RTV the piss out of it. Bolt it back down and there you have it. Then you just have to get the code deleted from the PCM via a tuner...because it won't run worth a sh*t without the EGR and the code still there...
okay..im sold on doing it now as long as someone can tell me how to remove it using hp tuners. still new to tuning and dont have a clue how to do this. i think i know how to remove the check engine light from coming on but thats it
