Thread: XP cam, new engine, Rich and studdering when hot, great otherwise
Results 1 to 10 of 10
  1. #1 XP cam, new engine, Rich and studdering when hot, great otherwise
    GT Level Member tylerbinski's Avatar
    Canada
    This problem has been going on for the last week since new install... I got the intercooler on a few days ago hoping it was just heatsoaking the motor..
    Everything is great, and after I boost around a lot, the car seems to run like ****, and spudder like mad... so I pull over and let it cool... then it seems better.
    I also saw smoke coming into the cabin once i popped my hood after pulling over lastnight...
    LTFT were at liek + 30 while it was spuddering like mad!
    I was ripping around on the highway, then i slowed down for construction and was going about 5mph.. then the car started "hunting" for idle, and before long I had to limp it to the off ramp at 5mph and pull over, pop hood and wait about 10 minutes.
    IAT = 59
    ECT = 85
    MAP values seemed high when nit ran like ****.. seeing 60@ 800rpm, TP 0%, 86kP at 950
    my fuel trims were + 39 and MAP = 103 , 1180rpm, 21% tp
    didn't see a single misfire.
    once cooled, the car runs just fine...
    Questions: 1 - where was the smoke coming from?
    Question: 2 - What could be causing this problem only when hot
    Question3 - Could the MAP sensor screw up when hot? and command more fuel?
    mod: new engine, xp cam, stg3 blower , 3.0, fullsize IC etc.
    Thanks for the help..
    Exhaust is new, so I woudln't expect there to be any leaks yet, but will not rule that out, EGR is deleted and blocked, I will be checking again for a vac leak but it seems ok currently.
    Thanks Guys.
  2. #2 Re: XP cam, new engine, Rich and studdering when hot, great otherwise
    Canada
    I'm going to check out the setting in the PCM for "Catalyst protection" change it from 500C to 800C since I have a hi-flow cat
  3. #3 Re: XP cam, new engine, Rich and studdering when hot, great otherwise
    Charles City, IA
    IS that ect in ferinheight or Celsius?
    SMGPFC Two Nipple General
  4. #4 Re: XP cam, new engine, Rich and studdering when hot, great otherwise
    Feb 2008
    Sounds like a vacuum leak
  5. #5 Re: XP cam, new engine, Rich and studdering when hot, great otherwise
    first off, LTFTs lock in at +16.4 at the maximum...dont know where youre getting +30.
    second, if they are locked high, you have a vacuum leak or a big exhaust leak.
  6. #6 Re: XP cam, new engine, Rich and studdering when hot, great otherwise
    TDCRacing
    Guest
    I'm going to shoot for a vacume leak.
  7. #7 Re: XP cam, new engine, Rich and studdering when hot, great otherwise
    wait...what? vacuum leaks means its lean. positive LTFT values are LEAN conditions.
  8. #8 Re: XP cam, new engine, Rich and studdering when hot, great otherwise
    Canada
    Temps in Celcius.. (canada)
    Well, I am still tuning, Currently running without a MAF (speed density tuning), making changes to the Volume Efficiency table... making great progress.
    As I said, the car is running fine most of the time, The first time I had the problem, I had been ripping around for a bit and the intercooler was not running so it was very hot (cooked some eggs on the blower...j/k)
    I was misfiring, and figured there could be a spark problem, so I removed the metal heat shields around the boots and squished the snap rings a bit tighter on the boots *these are the 10mm wires from ZZP and AL103 plugs...
    The car drove terrible after it cooled for only 10 mins... After it sat a while it was great, and I zipped around for a bit more and then parked the car.... 20 minutes later i started it up and zipped out of the parking lot and then the car was not happy so i pulled over n popped the hood to try cooling for 15-20 mins...
    Car ran fine for the trip home.
    ***Added fluid to intercooler and wired up the pump/fans....***
    Well I hadn't seen the problem for a few days then one night i took a 40km high speed zip down the highway, hit traffic and then the car started "hunting" for idle and started to sound like it was running on a few cylinders and i pulled over on the closest offramp..
    I had the scanner hooked up and was logging all the info... At the time the fuel trims were +30....
    I'm going to the exhaust shop tomorrow because I hear a small rattle at idle (sounds around the cat, but also in one of the mufflers)
    Perhaps there is a leak before the 02 sensor... but as i said , exhaust is brand new 2 weeks old..
    Appreciate all the help guys...
  9. #9 Re: XP cam, new engine, Rich and studdering when hot, great otherwise
    Canada
    bumpage
  10. #10 Re: XP cam, new engine, Rich and studdering when hot, great otherwise
    Canada
    Cat was blown apart, so the removed it and put in a "test pipe" for the duration of my tuning. no other leaks detected.
    unless something is expanding and letting in a lot of air when it gets really hot...
  1. Rich Condition HELP!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2009, 04:51 PM
  2. Rich Neighborhood :D
    By blueguy in forum Visual/Body Modifications
    Last Post: 05-15-2009, 12:06 AM
  3. Great DAY!
    By gptrell502 in forum Visual/Body Modifications
    Last Post: 04-25-2009, 10:31 AM
  4. 2000 GP SE rich fuel smell out of vents this morning.
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-29-2008, 08:54 AM
  5. Car runs rich and surges at an idle?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 02:54 PM
