Thread: Timing and other numbers...
Results 1 to 5 of 5
  1. #1 Timing and other numbers...
    Apr 2009
    stockton ca
    I had my scanner hooked up checking all the paramiters of the stuff it gives. Im also triing to figure out why my gas milage is so the way it is..
    My priogram is a genaric so it doesnt show knock
    It lists ltft,stft,timing,maf,vacuum,speed,rpms,tps,enginge temp,iat,o2 sensors,
    Is there a general guidline on where the paramiters should be at idle and 2500 , and wot
    Im going to go get some numbers from it and see where i am and maybe there will be some helpful info when i come back...
    Thanks
  2. #2 Re: Timing and other numbers...
    Barksdale AFB, LA
    All those numbers can vary so much based off the weather, elevation, throttle position, etc. We'd need to see a scan log to see how the numbers behave to really give you an idea of what's going on.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Timing and other numbers...
    Charles City, IA
    ltfts should be from -5 to 0. Never want it to be positive. 02's should be around 920 at wot. Eninge temp mine runs 185-192 depends on where I am at and outside temp.
    SMGPFC Two Nipple General
  4. #4 Re: Timing and other numbers...
    Apr 2009
    stockton ca
    Ok im working on geting a log that i can post just tring to figure out how to post it
    I know the ltft is at a positive 3. to 5 at times
    my timing during normal freeway driving is at 30* at idle it is at 20* and in boost it drops in to the low to mid teens
    And my map numbers dont seem right either
    Im just triing to figure out where Im suposed to be with all these numbers
  5. #5 Re: Timing and other numbers...
    Kansas City
    I have the magnaflow too and love it, they are cheaper on ebay but I wanted a warranty(salt in winter kills an exhaust) so I got it here. magnaflow 15906, or you can try one of the vendors here, they are allways runnign sales/specials. either way its a great system and very easy to install.
    LMAO
  1. Ok here is my dyno. Why aren't these the numbers I should be getting?
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 10:14 AM
  2. Here are Tag Numbers.....
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-24-2009, 02:43 PM
  3. Part numbers
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:50 PM
  4. Numbers
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-10-2008, 02:59 PM
  5. XP cam boost and vac numbers
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2008, 10:54 PM
