Thread: Ok here is my dyno. Why aren't these the numbers I should be getting?
Results 21 to 40 of 56
  1. #21 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    I dunno about the dyno results. Actually I'm goin to the dyno tomorrow so ill let u guys know what I get. I've got a 3.4 pulley, cai, zzp pcm, 180 tstat, tb spacer(bluh), 3" catless dp, plog, 8.5 mm wires, autolite 104s. So I hope to make decent power. ill let u guys know. And soon ill b goin to the track before it gets too hot. Good luck at the track bro
  2. #22 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    You've got a DHP man, no way I'd sell you a ZZP PCM...I don't want other cars to blow up like mine did
    You need to make it out to KCIR with the KCPMC group the next time we go
    And I still say youz knockin' bad like I did before
  3. #23 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    Apr 2009
    shawnee, kansas
    Ha! Sorry bout that. Yeah dhp pcm. Crap. Anyway yeah I'd love to get out there. Whens the next time their goin? You know? And I'm sure I'm knockin. Still wanna switch over to headers but oh well. Just got my plog on today. Was pretty easy to put on. Sounds better. But I got a decent jump in performance from it. Plus remember it was free so there u go
  4. #24 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    Quote Originally Posted by superv6 View Post
    Not sure...might be heading out this Friday...so today...around 5 or so. I'll have to call my buddy and see if he is rollin' out there in his Cobra to see what it throws down, he is hoping for 11's. If you go all your need is jeans/t-shirt/helmet/$20 to run all you want to...and if your knocking they have some race gas you can throw in there too
  5. #25 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    Apr 2009
    shawnee, kansas
    Well right on. Guess I missed that one. Anyway I'm gettin it dynod tomorrow. I'm gonna b goin to kcir sometime next week with my cousin. He's only got a brand new hyundai tiburon. Lol! But, if u wanna set somethin up to go at the same time let me know bro
  6. #26 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    anyone that has a TB spacer or the threaded/capped off coolant ports on the LIM is making their rear head run hot...
    just for your knowledge. you either need to port the coolant passage on the side of the LIM or leave it running through the blower/TB. it cools the rear head that way.
  7. #27 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    Guys the only knock I have is 0.2KR at my 3-4 shift. That is it. PRJ tuned my car. he knows what hes doing. my car was running lean or rich i cant remember (whichever ones makes your spark plug turn white) is what was going on. he fixed that.
    i went to the track last night for the first time. I ran a 15.3 my very first run. spinning like crazy. my second run was a 14.6 and i actually hooked pretty good. my reaction time was .185 and my 60' was 2.13.
    im going to scan some things today and see whats up. what should i be looking for on my scans??
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  8. #28 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    TDCRacing
    Guest
    KR, Timing, O2's
  9. #29 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    Donating Users blowfishRus6's Avatar
    g.a.
    did you happen to catch what the DA was?? there is a website that you can go and check it.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  10. #30 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    g.a.
    its slow.
  11. #31 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    Apr 2009
    shawnee, kansas
    Whew. That sucks. Figured ud be runnin quite a bit better than that. Oh well. R u at a weird elevation or anything? Wonder what's up?
  12. #32 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    May 2008
    staten island,NY
    what was the mph? reaction time doesnt mean anything. 60' time is what makes the difference. something isnt right if you are only putting down 200 to the wheels
  13. #33 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    Barksdale AFB, LA
    I wonder what his timing is at WOT?
    2009 Subaru Impreza WRX STI
  14. #34 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    Feb 2008
    South Bend, IN
    Altitude: 594ft.
    Timing at WOT: Near 20* according to PRJ.
    Here is the breakdown on my best run:
    Reaction: .1879
    60ft: 2.1869
    330ft: 6.1161
    ET @ 594 FT: 8.8221
    1/8: 9.4262
    1/8 MPH: 74.49
    1/4 ET: 14.6690
    1/4 MPH: 93.17
    I'm putting down 218 at the wheels and 236 TQ at the wheels. This was on a DYNOJET. Someone on here or somewhere else told me that I should divide the result by 1.13 to get the actual because a dynojet reads low????
    RESULT WITH ELEVATION FROM DRAGTIMES.COM CALC:--------------------------------------------------------------------------------
    Correct your ET and MPH using the DA (Beta Testing)
    Density Altitude: 2345
    feet above sea level
    1/4 mile ET: 14.66
    seconds
    1/4 mile trap speed: 93
    MPH
    Stock and Mildly Modified Naturally Aspirated Engines
    14.257 @ 95.69 MPH
    Extensively Modified Naturally Aspirated Engines
    14.396 @ 94.804 MPH
    Extensively Modified Supercharged and Turbocharged Engines
    14.511 @ 93.955 MPH
  15. #35 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    Feb 2008
    South Bend, IN
    I do have a throttle body spacer. Should I take it off it its heating up my LIM??
  16. #36 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    no, it is heating up the rear head. the rear head gets part of its coolant flow from the coolant that goes through the blower and throttle body. you need to open up the side of the lim and grind a little out of there so it has that ability to flow more coolant. there is a little cover that is on the side with a couple 10mm bolts.
  17. #37 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    g.a.
    i was traping 92 when all i had was an intake.
    last time out in 90* heat and 2800 DA i was still traping 97 and im on the stock tune and pulley.
    somethings not right, are your spark plugs good???
    its slow.
  18. #38 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    g.a.
    here is my 14.2 in 90* heat and 2800 DA. i traped 96 on that one and had a few 97's
    YouTube - gtp vs srt8 challenger
    its slow.
  19. #39 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    May 2008
    staten island,NY
    dynojet reads high, because there is no load on the rollers. hence why you divide to get the real number. as for your car, 04's and ups are dogs from the factory. something in your tune is not right. was it "street tuned". or strapped to the rollers and tuned?
  20. #40 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    Feb 2008
    South Bend, IN
    It was street tuned.
    I think im just going to get rid of the tb spacer then.
  1. New Dyno Tune Numbers
    By josh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2010, 04:27 PM
  2. Here are Tag Numbers.....
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-24-2009, 02:43 PM
  3. Part numbers
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:50 PM
  4. Numbers
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-10-2008, 02:59 PM
  5. Pacesetter header dyno numbers?
    By bevernden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2008, 09:23 AM
