Thread: Ok here is my dyno. Why aren't these the numbers I should be getting?
Results 1 to 20 of 56
  1. #1 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    Donating Users blowfishRus6's Avatar
    g.a.
    still looking for that 1.9 tho on street tires
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #2 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    this will be my first time at the strip too.
    what should i put the tires too? right now they are at 32psi all around. i have the pzer neros for the mustang gt so each tire i think is 10mm wider than stock.
    my gas tank is full!!
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  3. #3 Re: Ok here is my dyno. Why aren't these the numbers I should be getting?
    SE Level Member 04compggtp's Avatar
    Feb 2009
    new york
    hey good luck at the strip! I hope to see your time in the 13.8/9 range. It will give me a range to gauge my car. I told my brother, who is a huge camaro fan, that I believe I can get a 13.8 in my car and he and his friends were very skeptical. I do need to change my plugs again because I have noticed that I am not getting the pull from a 20 mph roll that I used to. Can't wait to see your results
    Thrasher cai, s&b 9",zzp stainless power log, zzp 3" cated dp, :180*t stat, autolite 104's, overkill pcm,: thrasher 3.4 modular pulley,F&R drilled/slotted rotors. 245/45/18 Fierce on Casino's
  1. New Dyno Tune Numbers
    By josh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2010, 04:27 PM
  2. Here are Tag Numbers.....
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-24-2009, 02:43 PM
  3. Part numbers
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:50 PM
  4. Numbers
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-10-2008, 02:59 PM
  5. Pacesetter header dyno numbers?
    By bevernden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2008, 09:23 AM
