98SilvermistGTP
That is good compression on number 2. You could check compression on them all just to be sure. Sounds like an LIM gasket. The gasket is plastic and a big piece of shiit, ufcking rediculous they used something like that. Look around the injectors and in the little spaces on the LIM to see if there is little puddles of coolant and oil mixed together. If you do, the LIM gaskets are bad. You could do some rockers and lifters while you are there, that would be a great time to do them if that is something you are going to do anyway.
