Thread: Factory Boost Gauge reading
Results 1 to 14 of 14
  1. #1 Factory Boost Gauge reading
    SE Level Member anicolay's Avatar
    Apr 2009
    Cottonwood, MN
    So how high should I see the boost gauge go...? I've never driven another GTP before to compare, I have a 97 bone stock... the highest it has ever gone is the notch just below the half way mark. No matter how much gas I give, thats the highest I've ever seen it go... should it go higher or is that about right?
    Thanks
    97 GTP - Daily Driver
    03 350z - Weekend Toy
  2. #2 Re: Factory Boost Gauge reading
    SE Level Member oldschoolpontiacs's Avatar
    Feb 2009
    BC Canada
    Are you talking about the digital boost gauge in the DIC?
    Sisters car: 1997 4-door GTP
  3. #3 Re: Factory Boost Gauge reading
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    I was able to peg mine out since day one
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: Factory Boost Gauge reading
    Apr 2009
    Cottonwood, MN
    Yes, that one, it never goes above half way-ish... should it go higher?
  5. #5 Re: Factory Boost Gauge reading
    GT Level Member SlowRR's Avatar
    Brookfield, IL
    it should go all the way
  6. #6 Re: Factory Boost Gauge reading
    Apr 2009
    Cottonwood, MN
    hmmm... so any ideas on why it doesn't??? car seems to be running fine, gets great gas mileage 29-31 on the highway, no engine codes, idle is perfect...
    Any ideas???
    Thanks
  7. #7 Re: Factory Boost Gauge reading
    CT
    BBV maybe? bleeding off boost?
  8. #8 Re: Factory Boost Gauge reading
    Feb 2008
    There's a boost bypass valve on the front driver's side of the blower. Check the vac lines going to it. If the vac lines are good, you may have a bad BBV.
  9. #9 Re: Factory Boost Gauge reading
    Banned - Busted For Scamming
    Feb 2009
    disconnect the line from the solenoid to the lower port on the diaphragm. Leave the solenoid still connected though to the wires or it will pop a code. That will fix your problem.
  10. #10 Re: Factory Boost Gauge reading
    Apr 2009
    Cottonwood, MN
    Are you referring to the last post...? Could you explain with a bit more detail... i'm only about 2 weeks into this car and its my first GM vehicle.
    Thanks
  11. #11 Re: Factory Boost Gauge reading
    GTP Level Member Scimmia's Avatar
    QCA, IA
    On the front of the supercharger, there's a black canister with a solenoid bolted to the same bracket. There's a vac line that goes from the solenoid to the canister. Disconnect it and just leave it hanging open, and see if the problem goes away. If so, it's a bad solenoid.
    2001 Buick Regal LS - Almost Stock
  12. #12 Re: Factory Boost Gauge reading
    Feb 2009
    ^yes they do, mine went bad causing the same problem, you dont need it, leave it disconnected. The only thing its used for is torque management. Screw the computer.
  13. #13 Re: Factory Boost Gauge reading
    Apr 2009
    Cottonwood, MN
    I like your attitude!!!
  14. #14 Re: Factory Boost Gauge reading
    Barksdale AFB, LA
    Quote Originally Posted by anicolay View Post
    I don't even have the solenoid.
    But I do have torque management for shifts since I happen to like my transmission. With the shift kit it shifts so fast the PCM doesn't have time to really affect engine power anyway.
    2009 Subaru Impreza WRX STI
  1. Getting half boost at the gauge.
    By falcz420 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 02:56 PM
  2. Boost gauge...
    By WayneG99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 08:52 PM
  3. boost gauge and etc...
    By Charged97 in forum General Tech Discussion
    Last Post: 02-28-2009, 04:16 AM
  4. Boost gauge on 03 gtp
    By brodyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 08:06 PM
