Thread: Got A Dilema, Which Engine Support
Results 1 to 20 of 23
  1. #1 Re: Got A Dilema, Which Engine Support
    Oklahoma
    Well I had thought of some ideas like that, but was kinda concerned about the ability to hold things up for long term if needed. But now that you have mentioned your using it, a couple new ideas popped in my head I may have to look at. What kind of pipe did you use, just regular steel pipe?
    I guess the major part of removing the tranny is removing the axles, the strut and mount, correct. Did you drop out the cradle too? If so, where do I find those round bushings at the mounting points for the cradle?
    I got some how to's on dropping out the tranny and a friend of mine just recently gave me a socket extension that is literally three feet long. 1/2" drive, but three feet long nonetheless. But I assume the major part of dropping out the tranny are the bell housing bolts and then supporting it and getting back up in there, correct?
  2. #2 Re: Got A Dilema, Which Engine Support
    chi-town
    i just used a piece of 1 1/2 steel pipe , like plumbing pipe , it was that or a 4x4 oiece of wood from pass strut tower to the lf core support, worked like a dream, also wrapped the ends in towles as not to slip or damadge paint.
    craddle out is a must i do believe ,at least i took mine out.
    i did it in this order
    jack stands on rocker
    tires off
    struts out
    pulled spindles all the way out (tied up calipers)
    unbolted rack from frame
    supported engine with pipe and straps
    removed all lines and wires clipped to craddle
    unbolted front mount and trans mount
    lifted engine just enough to raise it off the craddle
    took out l/f r/r craddle bolts
    double checked for anything i missed
    put another pait of stand under craddle and took remaining bolts out so the craddle would rest on other stands.
    craddle out
    disconnect shifter cable, wiring , and trans lines(should have done earlier , motor and trans wanted to rock around pretty good).
    jack under trans pan
    remove torque converter bolts
    remove bell housing bolts
    lowered jack and trans was out
    like i said it was my first w bodt trans r&r but out in 3-4 hours with many cig breaks , in about the same , alittle quicker.
  3. #3 Re: Got A Dilema, Which Engine Support
    chi-town
    it could probably be done with out , im spoiled and always used them. i would highly recommend using air tool , strut bolts and rack bolts would be a bear with out , also makes torque converter bolts easier , no need to hold the motor from spinning over.
    as for the round pipe , yeah square would be nicer ...... but in the heat of the battle i grab what i can....lol
  4. #4 Re: Got A Dilema, Which Engine Support
    chi-town
    sorry.... also make sure to check your abs wires as they are clipped all along the front of the support , you should be able to do it. aint as hard as i thought it would be.
  1. Service Engine??
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 11:55 AM
  2. NEW use for an engine hoist!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 02-08-2008, 11:51 PM
  3. Another interesting Engine
    Last Post: 02-03-2008, 07:55 PM
  4. car and Engine pics
    By Jason Austin in forum Visual/Body Modifications
    Last Post: 01-07-2008, 10:18 PM
