Thread: What is octane? KR? Explained here.
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 84
  1. #61 Re: What is octane? KR? Explained here.
    Jun 2011
    Detroit, MI
    Quote Originally Posted by 01gtprocket View Post
    Aboubt a week ago I see a no name truck pump gas at the cheveron . the same truck pumped at ampm... Then the very same day see him at the texaco.. I think gas is gas..
    This isn't true. Unless all of those places were independent, they couldn't be getting the same gas, plus there wouldn't be enough in one tanker to fill three gas stations...
    Each company (i.e. Chevron) refines their own oil, adding different detergents etc. Many people believe Chevron has better gas then other companies as well.
    Plus if the truck was "no name" how would you know it was the same one...
    iLoveSpade
  2. #62 Re: What is octane? KR? Explained here.
    May 2008
    Winnipeg, MB
    is KR an issue for n/a engines?
    2007 Pontiac Grand Prix
  3. #63 Re: What is octane? KR? Explained here.
  4. #64 Re: What is octane? KR? Explained here.
    Out West
    Quote Originally Posted by Hippo Machine View Post
    No.
    Whine with your Cheese?
  5. #65 Re: What is octane? KR? Explained here.
    Quote Originally Posted by tod1d View Post
    I had 8* of KR from the factory running on 87 octane, on a stock car with an intake/catback...which really do nothing but add noise.
  6. #66 Re: What is octane? KR? Explained here.
    Apr 2011
    Tally, FL
    i've seen 16-17* on my n/a with 87.
    Quote Originally Posted by Nixon View Post
    No.
    Beliefs of the leafmaster.
    Quote Originally Posted by DoubleBlown View Post
    Timing advance?
    I saw a 22-24 wot with 2* kr with headers on 94 octane. Go crappy 3800's.
  9. #69 Re: What is octane? KR? Explained here.
    36* Timing with stock manifolds...
    And 91?
    Wheeeeeeeeeeeeeeeeeeeeeeeeee
  10. #70 Re: What is octane? KR? Explained here.
    teh how?
    more importantly: teh why?
  11. #71 Re: What is octane? KR? Explained here.
    11.8-12.0:1 AFR.
    It's a N/A motor.
    Mike has close to the same timing with a leaner AFR.
  12. #72 Re: What is octane? KR? Explained here.
    Apr 2011
    Tally, FL
    Timing advance?
    16-17* of kr
  13. #73 Re: What is octane? KR? Explained here.
    Which is...possible?
  14. #74 Re: What is octane? KR? Explained here.
    May 2008
    Winnipeg, MB
    I'm going to install 180 t-stat and plog this weekend to see if that drops the KR. I see 5* of kr when speeding up. Overall just not fast enough with my mods and hope these new ones make a difference.
  15. #75 Re: What is octane? KR? Explained here.
    180ยบ is a waste of time and 10 bucks.
    Stock is perfectly fine.
  16. #76 Re: What is octane? KR? Explained here.
    Out West
    I ran 12.7 AFR and 35* WOT with no KR on 87 when i took the S/C belt off
    Low compression FTW.
  17. #77 Re: What is octane? KR? Explained here.
    Are you running 87 still?
  18. #78 Re: What is octane? KR? Explained here.
    May 2008
    Winnipeg, MB
    thats what the pcm is tuned for
  19. #79 Re: What is octane? KR? Explained here.
    No...pcms are tuned for higher octane. Go try 91 or higher. See if the knock goes away.
  20. #80 Re: What is octane? KR? Explained here.
    SE Level Member ms3206's Avatar
    Aug 2011
    Ohio
    How much KR is considered bad? At WOT on the highway I have 6* of KR. Should I be concerned by this? 05 GTP 3.4 pulley, CAI, tuned pcm, colder plugs, and 180* tstat
