Thread: what is normal ignition?
Results 1 to 3 of 3
  1. #1 what is normal ignition?
    SE Level Member comongoose's Avatar
    Jan 2009
    Gainesville, Fl
    On my scan gauge it says 27* at idle and goes down as i give it gas. Is this normal I always thought ignition went up with rpms? What is the standard? Do you guys think this indicates my crank pulley is not keyed in right?
    -1999 GTP...Work in Progress! L26 bottom end, K&N HAI, ZZP MPS 3.5" pulley, headers, custom intake, 180 therm., 1.9 rockers
    -1996 Acura TL
    -1995 Trans Am...SOM beast...RIP.
  2. #2 Re: what is normal ignition?
    on a boosted car you need to go down as you build more boost. on the stock PCM with stock timing youll be running ~16* WOT if you arent knocking at all.
  3. #3 Re: what is normal ignition?
    Barksdale AFB, LA
    Spark goes down as the amount of fuel going in goes up. It changes very little based off RPMs. FWIW, my idle is usually 27* +/- .5* .
    2009 Subaru Impreza WRX STI
  1. is this normal corrosion
    By millfire517 in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2009, 12:44 PM
  2. Engine Temperature Normal Range...
    By Chris in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 08:17 AM
  3. Occasionally Sputtering then back to normal? Help
    By Abrasive in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2009, 10:57 PM
  4. Normal coolant temp?
    By nboylie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2009, 08:46 PM
  5. Pictures.. engine look normal?
    By golden_c_ninja in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2008, 07:21 PM
